Install NM-1A-E3 in 3800 ISR
aseijas
Hi Everybody,
My customer has installed a 3825 ISR with this characteristics:
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
System image file is "flash:c3825-adventerprisek9-mz.124-4.T4.bin"
Cisco 3825 (revision 1.0) with 222208K/39936K bytes of memory.
Processor board ID FTX0949A01V
2 Gigabit Ethernet interfaces
4 Serial(sync/async) interfaces
1 ATM interface
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
As you can see it has 1 NM-1A-E3 and they want to install new one in the other slot available but we are not sure if that is possible. i mean, a router 3825 ISR can support 2 NM-1A-E3?
We checked datasheet but the info is no really clear.
paolo bevilacqua
Should be possible, of course being an access router depending on features enabled the CPU may be stressed a bit, better would be to use two independent routers, or one bigger 3845.
Hope this helps, please rate all useful posts!
thank a lot for your help about E3 ATM card in ISR 3825. indeed i checked the datasheet that is mentioned by other engineer here, but it doesnt result so helpful. my idea was confirm the info i got from a few sites here in cisco.
i send you an answer about your ISDN's question here in venezuela. i hope it help you.
regards,
alejandro
Amit Singh
Only one module is recommended to use in a 3825 router chassis.Please see the link below:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b9e.html
HTH,Please rate if it does.
-amit singh
Thanks Amit. It is a little bit of a peculiar datasheet as it doesn't mention a "supported" maximum number, rather just a "recommended" number. And I agree with this recommendation.
Anyway, the online configuration tool allows two modules in a 3725.
