BGP: aggregation with suppress-map
ameen.ahmed
Dear Friends,
I'm facing a problem with bgp suppress-map command.
---R1<-------->R2<------->R3---
I've configured loopback in R1 as below,
interface Loopback1
ip address 20.10.10.1 255.255.255.252
interface Loopback2
ip address 20.10.10.5 255.255.255.252
interface Loopback3
ip address 20.10.10.9 255.255.255.252
interface Loopback4
ip address 20.10.10.13 255.255.255.252
Configuration on R2,
router bgp 222
aggregate-address 20.10.10.0 255.255.255.0 suppress-map xyz
access-list 20 permit 20.10.10.12 0.0.0.3
access-list 20 deny  any
route-map xyz permit 10
  match ip address 20
As per the above configuration, I'm expecting R3 to show all routes except 20.10.10.12/30 in bgp table & routing table with a summary route pointing to 20.10.10.0/24. However, what I can see in R3 is, only a summary route, that too, 20.10.0.0/16.
Anyone know the reason pls?
R2 can't aggregate as it hasn't got any prefixes for the loopbacks in its BGP RIB.
Can you do sh run | s bgp on R1
Regards.
Alain.
cadet alain
on R2:
-sh ip bgp
- sh run | s bgp
-sh route-map
-sh ip bgp nei x.x.x.x advertised where x.x.x.x is R3
Regards.
Alain.
Dear Alain,
The requested logs are given below,
R2#
R2#
R2#sh ip bgp
BGP table version is 4, local router ID is 1.1.1.9
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 1.1.1.4/30       0.0.0.0                  0         32768 i
*> 1.1.1.8/30       0.0.0.0                  0         32768 i
*> 20.10.0.0/16     1.1.1.6                  0             0 111 i
R2#
R2#
R2#sh running-config | be router
router bgp 222
no synchronization
bgp log-neighbor-changes
network 1.1.1.4 mask 255.255.255.252
network 1.1.1.8 mask 255.255.255.252
neighbor 1.1.1.6 remote-as 111
neighbor 1.1.1.10 remote-as 333
no auto-summary
ip classless
ip http server
no ip http secure-server
match ip address 20
R2#
R2#
R2#sh ip bgp  neighbors 1.1.1.10 advertised-routes
R2#
R2#
R2#
R3#
R3#sh ip bgp
BGP table version is 211, local router ID is 1.1.1.10
*> 1.1.1.4/30       1.1.1.9                  0             0 222 i
r> 1.1.1.8/30       1.1.1.9                  0             0 222 i
*> 20.10.0.0/16     1.1.1.9                                0 222 111 i
R3#
R3#
Ameen Ahmed.
Regards.
Alain.
Hi Alain,
Thanks alot. There was aggregate command in R1 also which made this problem. When I removed it and everything worked fine.
R1#
R1#
R1#sh run | beg router
router bgp 111
no synchronization
network 20.10.10.0 mask 255.255.255.252
network 20.10.10.4 mask 255.255.255.252
network 20.10.10.8 mask 255.255.255.252
network 20.10.10.12 mask 255.255.255.252
aggregate-address 20.10.0.0 255.255.0.0 summary-only
neighbor 1.1.1.5 remote-as 222
no auto-summary
R1#
R1#
Once agian thanks.
Ameen Ahmed.
