BGP allowas-in and split horizon problem.
aselioscisco
I need some help. I can't understand why R2 advertises back the same networks to the neighbor from that received.
My topology is:
R1 is in AS1, R2 is in AS2 and R3 is in AS3, I've eBGP R1-R2, and eBGP R2-R3.
R1 and R3 has configured allowas-in to permit routes with their own AS.
The problem is with eBGP Updates. The router R1 advertise 1.1.1.1/32 to R2, and R2 sent back to R1 the same route 1.1.1.1/32.
I think that should not happen according the BGP split horizon rules. R2 should not advertise those networks who learned from R1, unless R2 has a route with better metric.
The same behavior happens between R2 and R3.
Thanks in advance.
All the router had the same IOS: c7200-is-mz.123-14.T1.bin
R1 Configuration
R1#sh run | sec router
router bgp 1
no synchronization
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
neighbor 172.28.1.1 remote-as 2
neighbor 172.28.1.1 allowas-in 10
neighbor 172.28.1.1 soft-reconfiguration inbound
no auto-summary
R1#
R2 Configuration
router bgp 2
no synchronization
neighbor 172.28.1.2 remote-as 1
neighbor 172.28.1.2 soft-reconfiguration inbound
neighbor 172.28.2.2 remote-as 3
neighbor 172.28.2.2 soft-reconfiguration inbound
no auto-summary
R2#
R3 Configuration
router eigrp 200
redistribute connected
redistribute bgp 3 metric 100000 10 255 100 1500
network 192.168.3.0 0.0.0.3
no auto-summary
router bgp 3
no synchronization
redistribute eigrp 200
neighbor 172.28.2.1 remote-as 2
neighbor 172.28.2.1 allowas-in 10
neighbor 172.28.2.1 soft-reconfiguration inbound
no auto-summary
R3#
R1 BGP Table, Advertised Route, Received Routes
R1#sh ip bgp
BGP table version is 6, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*  1.1.1.1/32       172.28.1.1                             0 2 1 i
*>                  0.0.0.0                  0         32768 i
*> 3.3.3.3/32       172.28.1.1                             0 2 3 ?
*> 4.4.4.4/32       172.28.1.1                             0 2 3 ?
*> 172.28.2.0/30    172.28.1.1                             0 2 3 ?
*> 192.168.3.0/30   172.28.1.1                             0 2 3 ?
R1#
R1#sh ip bgp neighbors 172.28.1.1 advertised-routes
*> 1.1.1.1/32       0.0.0.0                  0         32768 i
Total number of prefixes 1
R1#
R1#sh ip bgp neighbors 172.28.1.1 received-routes
Total number of prefixes 5
R1#
R2 BGP Table, Advertised Route, Received Routes
R2#sh ip bgp
BGP table version is 7, local router ID is 172.28.2.1
*> 1.1.1.1/32       172.28.1.2               0             0 1 i
*> 3.3.3.3/32       172.28.2.2               0             0 3 ?
*> 4.4.4.4/32       172.28.2.2          156160             0 3 ?
r> 172.28.2.0/30    172.28.2.2               0             0 3 ?
*> 192.168.3.0/30   172.28.2.2               0             0 3 ?
R2#
R2#
R2 Received routes from R1
R2#sh ip bgp neighbors 172.28.1.2 received-routes
R2#
R2 Advertised routes to R1
R2#sh ip bgp neighbors 172.28.1.2 advertised-routes
R2#
R2 Received routes from R3
R2#sh ip bgp neighbors 172.28.2.2 received-routes
Total number of prefixes 4
R2#
R2 Advertised routes to R3
R2#sh ip bgp neighbors 172.28.2.2 advertised-routes
R2#
R3 BGP Table, Advertised Route, Received Routes
R3#sh ip bg
BGP table version is 7, local router ID is 1.1.1.1
*> 1.1.1.1/32       172.28.2.1                             0 2 1 i
*  3.3.3.3/32       172.28.2.1                             0 2 3 ?
*>                  0.0.0.0                  0         32768 ?
*  4.4.4.4/32       172.28.2.1                             0 2 3 ?
*>                  192.168.3.2         156160         32768 ?
*  172.28.2.0/30    172.28.2.1                             0 2 3 ?
*  192.168.3.0/30   172.28.2.1                             0 2 3 ?
R3#
R3#sh ip bgp neighbors 172.28.2.1 advertised-routes
*> 3.3.3.3/32       0.0.0.0                  0         32768 ?
*> 4.4.4.4/32       192.168.3.2         156160         32768 ?
*> 172.28.2.0/30    0.0.0.0                  0         32768 ?
*> 192.168.3.0/30   0.0.0.0                  0         32768 ?
R3#
R3#sh ip bgp neighbors 172.28.2.1 received-routes
R3#
rais
Level 7
Level 7
Is that right your R3 has router-id 1.1.1.1? BGP advertising all BGP routes to neighbor has been another thread and I think it was normal behavior.
cadet alain
the BGP split-horizon rule states that a BGP speaker cant advertise any iBGP update to other iBGP peers, there is nothing about eBGP in this rule.As the AS_PATH is used for loop detection then even if it receives back the same prefixes it will not accept them but in your case as you are using allow as-in then you accept this update.
Regards.
Alain
dalal.sujal
I would agree with Alain
allowas-in will disable the BGP loop detection. The split horizon rule is for iBGP and not for eBGP. The only way you can prevent the prefixes coming back would be using some sort of tagging or prefix lists
-Sujal
barnesp
I agree with the previous posters.  What you could do is look at show bgp ipv4 unicast 1.1.1.1 on R2.  You will find that the prefix is associated with an update group.  An update group is an optimisation within the router BGP process to reduce the processing overhead for generating updates to peers.  If two peers have exactly the same outbound routing policy they would be in the same update group. If you looked at the update group show bgp ipv4 unicast update-group <number> you would probabably find that it would contain the peers 172.28.1.2 and 172.28.2.2.
This would mean that the 1.1.1.1 would be replicated to R1 and R3.  Without remoteas-in configured R1 would reject the prefix due the AS path containing AS1 - you can see this if you look at the output from show bgp ipv4 unicast neighbor 172.28.1.1 towards the bottom you will see the quantity of prefixes that have been rejected and why - use debug ip bgp updates if you want to see this in real time.
When remoteas-in is configured the prefix from R2 is accepted into the BGP table - however this is irrelevant as it will never become the best-path due to the weight 32768 for the local origination. If R1 peered with R4 via eBGP for example only this best path would advertised and hence nothing is broken.
