I am planning to upgrade one of the data center spine switch Nexus 7000.
Cisco says to remove inactive ACL
During an ISSU from Cisco NX-OS Release 5.2(x) or Release 6.1(x) to Release 6.2(2a), the system
prompts you to clear inactive access control list (ACL) configurations. Enter the clear
inactive-config aclcommand to clear any inactive ACL configurations.
But in my configuration, the command shows inactive ACL configuration which are applied on the SVI (e.g. see below) I am not sure why they are inactive. is this due to the bug CSCtf36357 n7k: Need ability to configure ingress netflow sampling with dhcp relay... but i am confused what will happen if I clear the inactive config..certainly I dont want to remove all my acls from the switch
gw01-vdc01(config-if)# sh running-config aclmgr inactive-if-config
!Command: show running-config aclmgr inactive-if-config
!Time: Wed Aug 20 10:49:54 2014
version 6.1(3)
interface Vlan60
ip access-group vlan60-in in
interface Vlan61
ip access-group vlan61in in
