BGP and MPLS peerings
yuchenglai
Hey All,
I was wondering if someone could help remind me whether or not BGP and / or MPLS LDP peerings have to occur using a / 32 address.  If so, why?
Thanks in advance!
David
do you mean IP addresses on loopback interfaces? It's not really necessary, you can use just a normal "link-net" address, but BGP and MPLS needs an uniqe router-id, and a loopback IP is normaly used for this.
Craig_Baum_2
And of course any /32 would require some form of routing (static or other for reachability) as opposed to say using a /30 address on a pt-pt Ethernet link for peering which would be picked up by the local network..
Marwan ALshawi
hi David,
you right you need a host route /32 for MP-BGP with MPLS
You need to use a /32 loopback as the router id for LDP. Without this the PHP is happening one hop too early. This causes to recieve an untagged frame instead of a MPLS frame
however for normal eBGP or iBGP you can use any interface with any subnet as long as it is reachable via IGP or directly connected
hope this help
if helpful Rate
