Cisco 1921 Router with Verizon Bridged ADSL Westell Modem
milkboy33
Hi All!
   So.. I'm stumped. We got a 1921 router that works fine. We ordered Verizon Businss One Static IP ADSL. It came with a Westell Modem that we configured in bridge mode. When we do a test by assigning a static IP to our laptop then hook it up to the Westell it works fine. We can browse the web. Then when we assign a static IP to the Ethernet on our 1921 then connect it to the Westell it doesn't work. We can't ping out from the router to for example 4.2.2.2. From the router we can't even ping the default gateway (on Verizon's side).
   I'm thinking there's something very simple we're missing. We're really frustrated and would appreciate any input.
Thanks all!
-Tom
Reza Sharifi
Hi Tom,
What is the purpose of putting the 2921 behind the Verizon Westell?  If you have users that need to access the Internet, you can connect a switch to Verizon router and let DHCP serves IPs from the router.  Can you post the config from the 2921 router?
The reason we want to put the 1921 behind the Westell Verizon DSL modem and to have the modem in bridged mode is so that we can use the one static public IP Verizon assigned to us. We want to be able to configure a site to site VPN to HQ (HQ doesn't have a problem they have a T1).
Here's our running config:
Current configuration : 2119 bytes
! Last configuration change at 20:43:55 UTC Fri Nov 18 2011 by xxx
version 15.0
hostname SJWHS-RTRSJ
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.200.1 192.168.200.110
ip dhcp excluded-address 192.168.200.200 192.168.200.255
ip dhcp pool SJWHS-POOL
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
dns-server 10.10.2.1 10.10.2.2
ip name-server 10.10.2.1
ip name-server 10.10.2.2
license udi pid CISCO1921/K9 sn xxxxxxxxx
username asiuser privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
username laadmin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
redundancy
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key xxxxxxxxxxxxxxxx address xxxxxxxxxxxx
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set IPSecTransformSet1 esp-3des esp-md5-hmac
crypto map CryptoMap1 10 ipsec-isakmp
set peer xxxxxxxxxxxxx
set transform-set IPSecTransformSet1
match address 100
interface GigabitEthernet0/0
ip address 192.168.200.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description Wireless Bridge
ip address 172.17.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0/0
description Verizon DSL for VPN Failover
ip address 17.108.63.249 255.255.255.0
duplex auto
speed auto
router eigrp 88
network 172.17.1.0 0.0.0.255
redistribute static
passive-interface GigabitEthernet0/0
passive-interface FastEthernet0/0/0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 17.108.63.1
access-list 100 permit ip 192.168.200.0 0.0.0.255 10.10.0.0 0.0.255.255
control-plane
line con 0
login local
line aux 0
line vty 0 4
login local
scheduler allocate 20000 1000
end
