BGP and OSPF redistribution
ncnaveen_arasu
When we have a network running with OSPF as IGP and MP-BGP for VRF network, how the OSPF learned routes will be redistributed to BGP and vice-versa.
Under address family vrf  'xxx'    We used to do redistribute satic and connected. this command will redistribute the vrf traffic to BGP.
How the plain traffic running by OSPF will redistribute with ospf.
How can we check the redistributed routes.
Please guide.
Thanks & regards,
Naveen
vishal vyas
I hope this example can help you to setup a redistrubution on your enviornment
router ospf 20 vrf XXXX
log-adjacency-changes
redistribute static
redistribute bgp 3 subnets
network 0.0.0.0 255.255.255.255 area 0
default-information originate
router bgp xx
address-family ipv4 vrf XXXX
  redistribute ospf 20 vrf XXXX
  neighbor x.x.x.x remote-as xxxx
  neighbor x.x.x.x activate
  neighbor x.x.x.x soft-reconfiguration inbound
vinayk3
Assuming you have the following desgin.
CE1------OSPF------PE1--------MPBGP-------PE2--------CE2.
on PE1 you should have the following config in terms of BGP and OSPF redistribution.
router ospf XX vrf vrf1
redistribute bgp YY subnets metric 10
address-family ipv4 unicast vrf vrf1
redistribute ospf XX subnets
no auto-summary
no synchronization
exit-address-family
You can check on PE2 if your redistributed routes are being received or not by
show ip route vrf X.X.X>X   ( where X.X.X.X ) can be any prefix being redistributed in BGP
also you can check if those prefixes are in BGP table.
show ip bgp vpnv4 all
Vinay
