BGP as-path prepend not working with peer-group?
vovochka83
router bgp 67111
bgp router-id 1.1.1.1
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor EBGP peer-group
neighbor EBGP remote-as 67222
neighbor 192.168.1.61 peer-group EBGP
neighbor 192.168.1.65 peer-group EBGP
address-family ipv4
redistribute ospf 1 route-map REDIST-OSPF-TO-BGP
neighbor 192.168.1.61 activate
neighbor 192.168.1.65 activate
route-map REDIST-OSPF-TO-BGP permit 10
match ip address prefix-list AAA
set origin igp
route-map REDIST-OSPF-TO-BGP permit 20
match ip address prefix-list BBB
set origin igp
set as-path prepend 67111 67111 67111
I couldn't see the as-path prepend on the peer router, is there any wrong on above configuration?
vovochka83
i found the issue, since it is using peer-group, so the route-map must be part of the peer-group as well. For example:
address-family ipv4
neighbor EBGP route-map REDIST-OSPF-TO-BGP
5 Replies 5
vovochka83
address-family ipv4
Hello
Try the following:
conf t
no set as-path prepend 67111 67111 6711
exit
ip prefix-list redistributed-ospf-routes permit x.x.x.x/yy
ip prefix-list redistributed-ospf-routes permit y.y.y.y/xx
etc...
route-map AS-path
match ip address redistributed-ospf-routes
exit
router bgp 67111
neighbor EBGP AS-path out
exit
clear ip bgp * soft out
Kind Regards
Paul
the route-map with peer-group command is working, also the prepend is working as expected, i just tested:
Do you mean that you kept the prepend command on both the individual peers and additionally to the peer-group? Because it seems also when applied only to the peer-group the prepend does not take effect.
Make new post let me check issue
MHM
