BGP atomic aggregate:
Wassim Aouadi
Level 4
Level 4
hi,
In Chris Bryant book, it is referred to as an attribute. In Cisco BSCI Command Reference, it is described as a "summary" address.
is it the summary route? or an attribute?
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
Jon Marshall
Wassim
It is a well-known discretionary attribute. It is used to notify downstream routers that a loss of path information has occured.
So the BGP router is advertising an aggregate address to downstream routers and the way it signifies that it has aggregated the address is to set the atomic aggregate.
Jon
lejoe.thomas
Level 3
Level 3
Hi Wassim,
Atomic aggregate is well known discretionary attribute of BGP.
When a BGP speaking router aggregates or summarises a group of specific routes into a less specific aggregate or summary, it attaches an atomic aggregate attribute to the aggregate or summary.
Lejoe
Nage Kaushik
Hi Sir,
Appreciate your response here. Where do you see "atomic aggregate" being used in the real world?
Thanks in advance
