bgp backdoor issue
Vinayaka Raman
The prefix 100.179.12.0/24 is learnt on tap via eBGP and eigrp..
i have set bgp backdoor command so that IGP wins over BGP
But it looks like even after hard reset, isn't working. can someone explain if i miss something here?
tap#show run | s r bgp
router bgp 65457
no synchronization
bgp log-neighbor-changes
network 100.179.10.0 mask 255.255.255.0
network 100.179.11.0 mask 255.255.255.0
network 100.179.12.0 backdoor
neighbor 10.0.0.2 remote-as 65457
neighbor 10.0.0.2 shutdown
neighbor 11.1.1.2 remote-as 65000
no auto-summary
tap#show ip bgp 100.179.12.0
BGP routing table entry for 100.179.12.0/24, version 5
Paths: (1 available, best #1, table Default-IP-Routing-Table)
  Not advertised to any peer
  65000 65458
    11.1.1.2 from 11.1.1.2 (152.0.0.1)
      Origin IGP, localpref 100, valid, external, best
tap#show ip route 100.179.12.0
Routing entry for 100.179.12.0/24
  Known via "bgp 65457", distance 20, metric 0
  Tag 65000, type external
  Last update from 11.1.1.2 00:05:15 ago
  Routing Descriptor Blocks:
  * 11.1.1.2, from 11.1.1.2, 00:05:15 ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 65000
tap#show ip ei top 100.179.12.0/24
IP-EIGRP (AS 1): Topology entry for 100.179.12.0/24
  State is Passive, Query origin flag is 1, 0 Successor(s), FD is 4294967295
  10.0.0.2 (Serial0/0), from 10.0.0.2, Send flag is 0x0
      Composite metric is (2297856/128256), Route is Internal
      Vector metric:
        Minimum bandwidth is 1544 Kbit
        Total delay is 25000 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
tap#
Regards Vinayak
Vinayaka Raman
is this the problem with mask?
Regards Vinayak
yes, it will be problem with mask. If you do not set mask, BGP thinks classful so network 100.179.12.0 backdoor means:
network 100.179.12.0 mask 255.0.0.0 backdoor which to no match 100.179.12.0/24.
Best Regards Please rate all helpful posts and close solved questions
mahmoodmkl
Level 7
Level 7
Can u incule mask in the backdoor command and try.
Ajay Raj
Since you have not added ask in backdoor command. It will consider ar /8 and there will be no effecte in that.
Give the command network 100.179.12.0 mask 255.255.255.0 backdoor
