BGP command Cisco 877 Router
drikilbride
Is it possible to set the following command on a Cisco 877 Router
router bgp 65500
At the moment it is saying it doesnt recognize the command and when I do router ? I don't see it in my list.
Thanks!
5 Replies 5
francisco_1
Level 7
Level 7
Post "show version" from the router
Francisco.
Giuseppe Larosa
Hello Drikillbride,
generally speaking it is a question of the IOS image running on the box.
you can use feature navigator tool (free access)
http://www.cisco.com/go/fn
and you can search by feature using BGP as the keyword then select platform =877
for example in 12..4T
c870-advipservicesk9-mz.124-24.T3.bin
if you haven't the correct feature set to upgrade you will need to purchase a license
if you have already a 15.0 IOS image you may have the correct image but you may need to install the correct license
post a
sh ver | inc image
to see what is in your device
Hope to help
Giuseppe
Hi All
This is what I get from the show version
ROM: System Bootstrap, Version 12.3(8r) YI4, RELEASE SOFTWARE
System image file is "flash:c870-advsecurityk9-mz.124-15.T7.bin"
Thanks!
Thanks for that, I will look into upgrading the license on it.
