BGP community value is not getting to the value set by route-map
Thiyagarajan K
Hello All,
I'm troubleshooting an issue with a community attribute in BGP. The community value which has been set for prefix using route-map is not propagated to the neighbour EBGP routers.
Could you please help me to isolate the cause of the issue and let me know what needs to be done to fix the issue?
Configuration:
route-map TEST-COMMUITY1 permit 10
set community 10:20 additive
router bgp 10
bgp log-neighbor-changes
network 30.0.0.0 mask 255.255.255.0 route-map TEST-COMMUITY1
BGP table output
BGP routing table entry for 30.0.0.0/24, version 2
Paths: (2 available, best #2, table default)
Advertised to update-groups:
Refresh Epoch 4
10 30
10.10.10.9 from 10.10.10.9 (10.255.0.54)
Origin IGP, localpref 100, valid, external
Community: 655380
rx pathid: 0, tx pathid: 0
Refresh Epoch 2
30
10.10.10.18 from 10.10.10.18 (10.255.0.56)
Origin IGP, metric 0, localpref 100, valid, external, best
rx pathid: 0, tx pathid: 0x0
Thiyagu
Thiyagu
Marking a question as answered can be done only by the original poster.
Rick
Rick
10 Replies 10
make sure you have
ip bgp-community new-format
configured on your router.
That will change the community 655380 to what you have configured, 10:20
The suggestion about using bgp-community new-format is a good one. But I wonder if it addresses the original problem. As I read the original post it seems that the community is not propagated not so much that it is the wrong format. I wonder if including send community in the BGP config is not also required.
Rick
Rick
Richard,
I might have missed something, not sure. I thought the community that is shown in the output, 655380, was the one that is propagated, just not in the right format...?
655380 --> 10100000000000010100
1010 : 0000000000010100 = 10:20
which would be the community set in the route map...
My understanding of the original post is that the community is not propagated. Perhaps what was intended was that it was not in the expected format and therefore seems not propagated. We need clarification from the original poster about this.
Rick
Rick
Thanks a lot guys for your valuable inputs. My issue was the community propagation was not in the correct format. my expected community value is 10:20 but I'm finding the value of  655380 on the neighbor router.
do I need to add the command "ip bgp-community new-format" on the neighbour router?
ip http authentication local
no ip http secure-server
Thiyagau
Thiyagau
Thank you for clarifying that the real issue was the format in which the community was displayd. So the suggestion about specifying ip bgp-community new-format was the better suggestion.
The ip bgp-community new-format command controls the display of the community value. So it would be important that the neighbor router have this command. It would probably be advisable if your router had the command also. You can use this link to find additional details
http://www.cisco.com/c/en/us/td/docs/ios/iproute_bgp/command/reference/irg_book/irg_bgp2.html
Rick
Rick
Thanks a lot all for your quick help. Adding the command "ip bgp-community new-format" took care of the issue.
Thiyagu
Thiyagu
Thanks for posting back and confirming that adding the ip bgp-community new-format did solve your problem. So it would be appropriate to mark this question as answered.
Rick
Rick
Rick,
Please mark as answered and thanks again for your prompt reply.
Thiyagu
Thiyagu
Rick
Rick
