BGP confuesion
M.Sultan
Look the diagram below !
Ospf is full meshed as underlaying and all physical interfaces added to ospf routing domain, and then applied iBGP using loopback interfaces of each router, and eBGP using physical interface of each connected router, now from R12 I see only routes loopback interfaces, and from R12 i can ping all loopbacks but not the physical interfaces which was added to ospf.
What is wrong ?
 Do I need add all physical interfaces into ibgp ? or i do redistribution ? I'm confused !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so steps need to make full mesh work
config iBGP between all router
add interface between routers (and LO if you use it as update source) to OSPF
config iBGP
next-hop
self
that it
each router Now know the
next-hop
for any prefix advertise via iBGP
if you dont config full mesh you need to redistrubte the iBGP prefix into OSPF
hope this clear this topic
thanks
MHM
we are talking about this part of your topology
there is iBGP mesh between R5 R6 R7 and R8
M.Sultan
Oh I see no need for redistribution because i can ping all routers due to full mesh!
config iBGP
next-hop
self
that it
next-hop
thanks
MHM
