BGP confusion
rhltechie
Hi all,
I was helped yesterday with some routing protocol issues. going to an mpls network that will only allow BPG or static. I found a BGP config in this group but just wanted some clarification as i am new to the BGP world.
setup as follows:
internet
CE1 - - PE1- - - -PE2 - - -CE2
CE3- - internet
The internet connection at CE1 is our primary and the internet at CE3 is a backup.
the PE routers are handled by the provider, as i understand i see them an a logical router and nothing more.
my confusion is how the sites know that the backup internet at CE3 is to be used if connection is cut at CE1. i understand default routes and such, so am i to just let the provider know which is backup and they handle it? i was thinking of something like the following for a template for all CE routers:
interface Serial0/0
ip address x.x.x.x 255.255.255.252
router bgp 65000
neighbor <PE router> remote-as 65002
network <internal net> mask 255.255.255.0
redistribute connected
no auto-summary
ip route 0.0.0.0 0.0.0.0 <PE router>
am i totally off base here with my thinking of BGP?
Thanks for any help.
I deliberately left out the network statements for CE1 and CE3. The only thing that needs to be advertised by these routers is the default route. You could advertise all the specific routes but there is little point in doing so.
Hope that helps - pls do rate the post if it does.
Paresh
7 Replies 7
pkhatri
Level 11
Level 11
Q: " how the sites know that the backup internet at CE3 is to be used if connection is cut at CE1"
The answer to this question is that the sites will not know that this is the case. This is key to the way an MPLS VPN works. Since your spoke sites have only a single link to the network, they have no choice but to send all traffic over this link. Once the traffic reaches the PE, the PE makes a determination of where the traffic has to go. Therefore, when the connection to CE1 is cut, it is the PE that has to make the switch to CE3.
Your config for the spoke routers is fine except:
- you do not need to use 'redistributed connected' if you are going to be specifying the networks to be advertised using the 'network' command.
The config for your CE1 and CE3 routes will have to be slightly different:
router bgp 65001
neighbor remote-as 65002
neighbor route-map SetMed out
default-information originate
no auto-summary
access-list 1 permit 0.0.0.0 0.0.0.0
route-map SetMed permit 10
match ip address 1
set metric 100 ! use this at CE1 only
set metric 0 ! use this at CE3 only.
The use of different MED values will allow the PE to choose between the two default routes from CE1 and CE3
Hope that helps - pls rate the post if it does.
Paresh
I would rather recommend using as-path prepending on the CE3 side since many SP providers reset the incoming MED for incoming BGP updates for L3VPN services.
This way default route from CE1 would always be picked first and the one from CE3 would be picked in case CE1 stops sending its default route or if it goes away all together.
The config would look something like this on CE3:
route-map AS-prepend permit 10
match ip address 1
set as-path prepend 65001
Hope this helps,
so if this is not used what exactly happens?
If you don't make sure that the default route from CE1 is always used as a primary, PEs in the core would select the default route from either CE1 or CE3 as the best path depending on the IGP distance to the PEs connected to CE1 and CE3.
Hope this helps,
Thank you for your reply, both of you.
pkhatri, a question about the config you posted. did you leave out the network statements because i had included them earlier? this cannot be the entire config without supplying the network correct? or are these the configs for the CE1 and CE3 and do not include the networks? just a little confusion on my part.
Thanks again.
Paresh
AH! lol I think i am coming around now...ha!
thanks so much for your help.
