BGP Cost Community and Point of Insertion
walter1972
Looking at the BGP Cost Community, I keep reading about how this influences the BGP best path selection process at the point of insertion (POI). Does this mean that the decision is taken immediately after step 8 in the Best Path Algorithm - ie Prefer the path with the lowest IGP metric to the BGP next hop?
For some reason I cannot get my head round this POI stuff.
6 Replies 6
Harold Ritter
Walter,
The POI indicates when, in the BGP best path selection process, the cost community is taken in consideration. There is only two choices for the value of the POI:
Router(config-route-map)#set extcommunity cost ?
<0-255> Community ID
igp Compare following IGP cost comparison
pre-bestpath Compare before all other steps in bestpath calculation
So as you can see it can be either compared before everything else (pre-bestpath) or right after the IGP cost comparison (igp).
Great answer - Thanks very much!
When I look at the options for this command it appears to me that there are actually 3 different scenarios: I can select IGP, pre-bestpath or I can not specify the POI at all.
The question is, if I don't specify, which is chosen? The documentation leads me to believe that it would be IGP by default but the fact that there is a specific keyword for IGP makes me doubt myself.
Any thoughts?
Edit:
Nevermind, I figured this out the easy way, just try it. If you don't specify either option it does just default IGP and actually adds that keyword into the config.
IR0(config)#route-map test-cost-comm
IR0(config-route-map)#set extcommunity cost 1 100
IR0#show run | sec route-map test-cost-comm
route-map test-cost-comm permit 10
set extcommunity cost igp 1 100
IR0#show route-map test-cost-comm
route-map test-cost-comm, permit, sequence 10
  Match clauses:
  Set clauses:
    extended community Cost:igp:1:100
  Policy routing matches: 0 packets, 0 bytes
Message was edited by: Robin Martinez
flezure
By default POI value is129, so POI of coat community in BGP path selection criteria comes right after IGP metric.
But we can change POI value with below command. With POI as 131, cost community  is considered after the BGP path attribute -Router ID assessment. With POI as, cost community is after 'Oldest path'. With POI as 128, cost community is considered well before 'Weight' ie after 'valid next hop'. This proves BGP is so flexible only one should know how to handle it.
Command is
set extcommunity cost <cost>:<POI>:<cost comm ID 0to255>:<cost value 0 to 2^32-1>
Hello
Yes POI is evaluated after ibgp cost to nexthop.
Here the cost comm will become the tie breaker evaluated on its assigned ID and cost (default 2.1 billion if not assigned)
lastly POI defaults to IGP
Kind Regards
Paul
