BGP de-aggregation
Kevin Dorrell
Level 11
Level 11
What is the best way to de-aggregate a prefix in BGP?  By which I mean I have a /22 prefix in my network, let us say 192.0.96.0/22, but my BGP peer will only accept /24 routes from me.  So I need to split it up into 192.0.96.0/24, 192.0.97.0/24, 192.0.98.0/24, and 192.0.99.0/24.
I know how to use aggregates to combine routes, so that if any fragment of the aggregate is in my BGP, then the aggregate gets advertised.  But can I do it the other way: that is declare some /24 aggregates, and if my /22 exists then the /24s get advertised?  If not, can you suggest another way of doing it?
Thanks in advance
Kevin Dorrell
Luxembourg
milan.kulik
Level 11
Level 11
Hi Kevin,
BGP Conditional Route Injection should be a solution for you.
See
http://www.cisco.com/en/US/customer/docs/ios/12_2t/12_2t4/feature/guide/ftbgpri.html
for details.
BR,
Milan
5 Replies 5
milan.kulik
Level 11
Level 11
Hi Kevin,
See
for details.
BR,
Milan
Hi Milan,
Thanks for the answer.  How frustrating!  The feature is exactly what I need, and my switches do support it ... but apparently not in a vrf !
At the moment I am originating the /24 prefixes using static routes and network statements, but that is not ideal precisely because they are static routes.  Back to the drawing board.
But your answer to the question I posed is correct, so thank you for the idea.
Kevin DORRELL
Luxembourg
Hi Kevin,
I suppose you are receiving the /22 prefix via some IGP from your network?
So wouln'd it be possible to configure the /24 static routes somewhere deeper in your network where it would not create any redundancy problem?
BR,
Milan
I suppose I could.  The /22 is actually an oversized data centre VLAN, spanning two sites.  - histerical historical reasons.  The VLAN is served by SVIs on two L3 switches in HSRP, each of which advertises the /22 into OSPF.
So, on the data centre switches, as well as the connected /22 routes for the VLAN SVI, I could configure four /24 statics pointing to the VLAN SVI, and redistribute those into the OSPF.
I am thinking aloud here, and I wonder if I have painted myself into a corner.  The area that carries the VLAN is a totally stubby, so redistribution may be out of the question.  Or is it?  The data centre switches are also ABRs, so I guess the re-distribution would be into area 0, which would be OK wouldn't it?  I should try it in the lab first.
Thanks for the reply.
Best regards
Kevin
Hi Kevin
I am using suppress-map to de-aggregate and to inject specific routes in the routing table. If you need further information please let me know I have a scenario handy.
