TRYING TO GET CCENT Need Help with Understanding few topics
mnoote191
I am trying to make sure I get this right the only time you use the clock rate command on the router is in lab enviornments not in real world because in lab enviornment you are using two routers connected with a DCE/DTE cable and one router is supplying to clock rate. But in real world the CSU/DSU are supplying the clockrate but even if the clockrate is supplied by the CSU/DSU does the router still need to be configured with that clock rate that the CSU/DSU supplied or does the router pick up the clock rate automatically and will the test be based on LAB Enviornment or Real World I just want to make sure I get this right
Also with clockrate and bandwidth commands do you have enter both commands on the routers when configuring clock rate speeds I guess for lab enviornment end or real world  in whats the difference between clock rate bandwidth other than the unit at which they use which clock rate command uses bps, and bandwidth uses kbps
Thanks so much
Michael Noote
5 Replies 5
Jan Hrnko
Level 4
Level 4
Hi Michael,
Well in most real wold cases - provider will be the one that has clock configured, so your device will be a DTE. No clock rate command needed (clock will be provided to you).
In laboratory conditions, you must configure both sides (DCE(provider side) and DTE).
clock rate and bandwidth commands are totally different commands and please, do not consider them interchangeable or something like that. Both have different purpose that will show up later in your studies.
clock rate - this one is pretty much obvious, as you stated - it sets the actual rate in bps(bits per second)
bandwidth - has no impact on speed of the link but has quite an impact in many different things. For example: It is used by routing protocols such as EIGRP,OSPF for metric calculation or in QoS (Quality of Service). I have read that also TCP will adjust its initial  retransmission parameters based on the bandwidth configured on the  interface but I have not tested it.
Best regards,
Jan
mnoote191
Thank you very much for explaining that Jan big help
Michael Noote
mnoote191
Thanks for help very much
Michael Noote
Hi Michael,
I am more than happy to hear that!
Congratulations!!!
Take care.
Best regards,
Jan
mnoote191
U to take care very much appreciated
Michael Noote
