BGP default route not being installed in the routing table.
ergamusai
I have a multihoming BGP setup, one 6509 connected to two ISPs. One is the primary, and one is the backup.
I am receiving only default routes from both ISPs. The BGP neighborship is established, but both default routes received have the rib-failure flag.
router bgp 55555
bgp log-neighbor-changes
neighbor 1.1.1.1 remote-as 111
neighbor 1.1.1.1 version 4
neighbor 2.2.2.2 remote-as 222
neighbor 2.2.2.2  version 4
address-family ipv4
network X.X.X.X mask 255.255.254.0
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 weight 50
neighbor 1.1.1.1 soft-reconfiguration inbound
neighbor 1.1.1.1 distribute-list 1_IN in
neighbor 1.1.1.1 distribute-list 1-OUT out
neighbor 2.2.2.2 activate
neighbor 2.2.2.2  send-community
neighbor 2.2.2.2  weight 40
neighbor 2.2.2.2  soft-reconfiguration inbound
neighbor 2.2.2.2  route-map 2_OUT out
exit-address-family
interface Vlan10
description ISP Connections
ip address 2.2.2.3 255.255.255.248 secondary
ip address 1.1.1.2 255.255.255.248
r> 0.0.0.0 1.1.1.1 50 111 i
r 2.2.2.2 40 222 i
The only way I can make this scenario work is by adding the static routes
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 0.0.0.0 0.0.0.0 2.2.2.2
Even when I remove the static routes both default routes I receive have rib-failure flag
Thank you in advance,
16 Replies 16
Did you leave the default static routes with an administrative distance of 220 so we can investigate further?
If so, can you show us the current "router bgp" config, the output of "show ip bgp 0.0.0.0" the and output of "show ip route 0.0.0.0".
not sure if you ever solved this, but you need to redistribute you connected and static routes into BGP.
