BGP doesnt send MED value on default route
rasmus.elmholt
Level 7
Level 7
I'm trying to manipulate some bgp attributes but can't get a route-map to change the MED value on the default route.
I have created a simple route-map to change the MED value on outgoing routes to a neighbor:
R2#show run | sec BGP-MED
router bgp 65000
neighbor 195.2.2.5 remote-as 65012
neighbor 195.2.2.5 default-originate neighbor 195.2.2.5 route-map BGP-MED out route-map BGP-MED permit 10 set metric 200
And the metric on all routes exept the default is changed when it arrives at the neighbor router(Se the attached picture)
How do i change the MED value of the default route as well?
2 Accepted Solutions
To change the metric value, you will need to add route-map in the default-originate statement:
neighbor 195.2.2.5 default-originate route-map BGP-MED
HTH,
Meheretab
HTH,
Meheretab
HTH,
Meheretab
HTH,
Meheretab
Than you, just the command i needed.
