IOS file copy gets stuck in cisco 3850 switch
nagasheshu.2014
Hi All,
I am trying to copy IOS cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin from TFTP server (windows  2008 server) or another 3850 switch (which is directly connected to the 3850 switch in which I am copying), is gets stuck after some time (say probably after 60%). No error or anything appear on screen, its just putty goes inactive.
I tried removing execution timeout, no luck.
any suggestions please?
its a 3850 stack switch and has 2 GB of memory free, IOS file i am copying is of 284 Mb.
Thanks in advance,
Nagasheshu.
5 Replies 5
Julio E. Moisa
TFTP does not support more than 30 - 32 Mb of transfer, I suggest to use FTP instead.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
This is the second 3850 stack switch IOS upgrade I am doing, and the first one did accept same file over TFTP. :-)
Nagasheshu.
What TFTP sofware is running on the server.
Try using TFTPd32/TFTPd64 (it's free).
Julio E. Moisa
rasmus.elmholt
Level 7
Level 7
I Would recommend using SCP instead, secure and more reliable than TFTP.
I use Putty PSCP to transfer files to the switch
!Enable SCP on the switch
ip scp enable
!Transfer file from the computer to the swtich
pscp -scp localfile.bin username@<switchip>:
