BGP Down messgages, want to know exact line wise issue and it exact meaning
nokiacare-vfcen
65791: Mar 3 02:53:14.759: %BGP-3-NOTIFICATION: sent to neighbor 182.19.96.80 4/0 (hold time expired) 0 bytes
065792: Mar 3 02:53:14.760: %BGP-3-NOTIFICATION: sent to neighbor 182.19.96.17 4/0 (hold time expired) 0 bytes
065793: Mar 3 02:53:14.760: %BGP-5-NBR_RESET: Neighbor 182.19.96.80 reset (BGP Notification sent)
065794: Mar 3 02:53:14.760: %BGP-5-NBR_RESET: Neighbor 182.19.96.17 reset (BGP Notification sent)
065795: Mar 3 02:55:24.432: %BGP-5-NBR_RESET: Neighbor 182.19.96.80 passive reset (Peer closed the session)
065796: Mar 3 02:55:25.035: %BGP-5-NBR_RESET: Neighbor 182.19.96.17 passive reset (Peer closed the session)
065797: Mar 3 03:04:31.355: %BGP-5-ADJCHANGE: neighbor 182.19.96.17 Down BGP Notification sent
065798: Mar 3 03:04:31.356: %BGP_SESSION-5-ADJCHANGE: neighbor 182.19.96.17 VPNv4 Unicast topology base removed from session BGP Notification sent
065799: Mar 3 03:04:31.356: %BGP-5-ADJCHANGE: neighbor 182.19.96.80 Down BGP Notification sent
065800: Mar 3 03:04:31.356: %BGP_SESSION-5-ADJCHANGE: neighbor 182.19.96.80 VPNv4 Unicast topology base removed from session BGP Notification sent
065801: Mar 3 03:04:31.359: %BGP-3-NOTIFICATION: received from neighbor 182.19.96.80 passive 4/0 (hold time expired) 0 bytes
065802: Mar 3 03:04:31.359: %BGP-3-NOTIFICATION: received from neighbor 182.19.96.17 passive 4/0 (hold time expired) 0 bytes
065803: Mar 3 03:04:33.145: %BGP-5-ADJCHANGE: neighbor 182.19.96.17 passive Down Peer closed the session
it is impossible to judge from the output you posted what caused the outage. If you are using the default hold timer (180 seconds) the line must have been done for quite a bit.
Is there anything else in the logs ?
Thanks Georg, So nothing is suspecting on our this router
Want to know exact meaning for below 2 lines
002712: Mar 3 03:04:34.206: %BGP-5-ADJCHANGE: neighbor 182.19.96.17 Down BGP Notification sent
The output means that the problem is likely at the peer, that is, the other end. Is the peer under your administration, or is that an ISP router ? Check with your provider, they should be able to see something in their logs...
