BGP - Error vrf
LincolnR
Hi Guys.
Im do a lab bgp on EVE and it Im tryed config a vrf. But display the error below. What can be causing error?
R7(config-router)#address-family ipv4 vrf BLUE
% Invalid address family ipv4 unicastvrf(0x1) BLUE
The issue happens because you have not enable address-family ipv4 under vrf definition.
vrf definition BLUE
address-family ipv4
exit-address-family
Giuseppe Larosa
Hello @LincolnR ,
check the name of the vrf you may have configured vrf BLU for example and you are attempting to configure a non existing vrf.
Hope to help
Giuseppe
Giuseppe,
Apparently the VRF name is the same.
vrf definition BLUE
rd 1:1
These are commands Im tryed.
neighbor 200.1.27.2 remote-as 500
neighbor 200.1.27.2 activate
exit-address-family
vrf definition BLUE
address-family ipv4
exit-address-family
Great Harold Ritter,
I needed to configure this feature.
