04-16-2017 07:45 PM - edited 03-05-2019 08:21 AM
Any help to understand this config, how does the router run the BGP on this sequence of config, correct me if im wrong but the prefix-list "Upstream-1" permits to advertise anything and then the "filter-list 1" permits to advertise routes local to this Router ASN right? is the prefix list necessary? did i understand the filters correctly?
neighbor 192.168.1.1 activate
neighbor 192.168.1.1soft-reconfiguration inbound
neighbor 192.168.1.1prefix-list Upstream-1 out
neighbor 192.168.1.1filter-list 10 in
neighbor 192.168.1.1filter-list 1 out
ip prefix-list Upstream-1description Prefix Advertise to Upstream-1
ip prefix-list Upstream-1 seq 100 permit 0.0.0.0/0 le 32
ip as-path access-list 1 permit ^$
ip as-path access-list 10 permit .*
Solved! Go to Solution.
04-16-2017 08:51 PM
Hi Roel,
Yes, you are right.
This line represents = Advertise every prefix to the neighbor 192.168.1.1
This line represents = Receive everything from the neighbor 192.168.1.1
This line represents = Advertise everything originated with the local AS
If you are protecting your BGP domain in order to advertise to the neighbor the prefixes originated into the local AS only, the line related to the prefix list could be removed because it could generate issues advertising the prefixes to the neighbor, in few words the BGP will not able to advertise nothing to the neighbor.
Hope it is useful
04-17-2017 10:15 AM
The result of these two filters on outbound advertisement to neighbor 192.168.1.1 is that you will advertise all locally originated routes to the neighbor and you will advertise only locally originated routes to the neighbor.
I would suggest that prefix-list Upstream-1 out is not needed. It does no harm to have it in the config (and the config might seem more complete with it in) but if you remove it the routes advertised to the neighbor would not change.
Rick
04-16-2017 08:51 PM
Hi Roel,
Yes, you are right.
Hope it is useful
04-16-2017 09:48 PM
hi sir,
But how will the filters work? permit anything first since i got this config "neighbor 192.168.1.1prefix-list Upstream-1 out"
then
filter anything other than my local AS routes ? "neighbor 192.168.1.1filter-list 1 out"
04-17-2017 10:15 AM
Rick
