08-08-2021 11:30 AM
Can BGP flap becasue of an over utilized interface? If so why would it flap? Is it becasue the hold timers are timing out?
Solved! Go to Solution.
08-08-2021 01:10 PM
I guess your explanation answered your own question. The overutilized interface looked to BGP like a down interface, so it was flapping...
08-08-2021 01:47 PM
If you do not like the BGP to flap, then reserve some bandwidth to BGP, using policy map :
you can find example :
=====️ Preenayamo Vasudevam ️=====
08-08-2021 12:15 PM
I guess a heavily overutilized interface would drop traffic because the buffers cannot handle the amount of packets. If BGP keepalives do not make it through either, BGP would flap.
08-08-2021 12:24 PM
The link was 90 to 100 percent overutilized. The core switch was doing the load balancing for both routers. I shut down the connection from the core going to the router that BGP was flapping and overutilized on. The flapping stop almost right away. I was not sure if it was coincidence or not. When I brought the connection back up the switch was load balancing correctly again and did not see any flaps.
08-08-2021 01:10 PM
08-08-2021 01:15 PM
08-08-2021 01:47 PM
