BGP Full View with ASR1001-X
matou801
I want to set up a full view with my transit provider
My transit provider tells me about 700,000 routes, but after 5 minutes I only have 455,000 routes added to my router.
I do not see where is the blocked?
Thanks for your help
My bgp config :
router bgp 0001
bgp router-id 194.XXX.XX.X
bgp log-neighbor-changes
neighbor IPV6:IPV6::33:0:6 remote-as 0002
neighbor IPV6:IPV6::33:0:6 description my provider transit
neighbor IPV6:IPV6::33:0:6 shutdown
neighbor XXX.XXX.XXX.169 remote-as 0002
neighbor XXX.XXX.XXX.169 description my provider transit
address-family ipv4
network 194.XXX.XX.0 mask 255.255.252.0
network 194.XXX.XX.0 mask 255.255.255.240
network 194.XXX.XX.32 mask 255.255.255.224
no neighbor IPV6:IPV6::33:0:6 activate
neighbor XXX.XXX.XXX.169 activate
neighbor XXX.XXX.XXX.169 next-hop-self
neighbor XXX.XXX.XXX.169 remove-private-as
neighbor XXX.XXX.XXX.169 soft-reconfiguration inbound
neighbor XXX.XXX.XXX.169 prefix-list PFX-LZI out
exit-address-family
address-family ipv6
neighbor IPV6:IPV6::33:0:6 next-hop-self
neighbor IPV6:IPV6::33:0:6 remove-private-as
neighbor IPV6:IPV6::33:0:6 soft-reconfiguration inbound
neighbor IPV6:IPV6::33:0:6 prefix-list PFX-V6-LVI out
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 194.XXX.XXX.XXX 255.255.252.0 Null0
ip bgp-community new-format
ip as-path access-list 1 permit ^$
2 Accepted Solutions
I come back to you for my problem. Finally after trying again, we encountered the problem.
My router did not see all the routes that my ISP was announcing to me when I did a show ip route after 30 minutes. I made a clear bgp and the all routes were added to my router. So everything works for the full view now.
Yes without change path list filter.
25 Replies 25
it seem to me it CE side.
you must check the route-target for import are you import all site or few one.
Hello @MHM Cisco World
I would expect like you its a CE rtr so then they wouldnt have any RTs etc the advertisment will come from the ISP
Kind Regards
Paul
balaji.bandi
Can you post below information :
show ip bgp summary
show version
show memory
BB
Thank you for quicks reponses.
#show ip bgp summary
BGP router identifier 194.XXX.XXX.XXX, local AS number 000002
BGP table version is 1534986, main routing table version 1534986
4 network entries using 992 bytes of memory
4 path entries using 544 bytes of memory
2/2 BGP path/bestpath attribute entries using 560 bytes of memory
1 BGP AS-PATH entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 2120 total bytes of memory
BGP activity 815609/815605 prefixes, 816000/815996 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
000.000.000.169 4 000002 279211 3007 1534986 0 0 1d21h 1
#show version
Cisco IOS XE Software, Version 16.06.02
Cisco IOS Software [Everest], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.6.2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 01-Nov-17 07:26 by mcpre
ROM: IOS-XE ROMMON
rt-01-xxx-XXX uptime is 1 day, 22 hours, 52 minutes
Uptime for this control processor is 1 day, 22 hours, 53 minutes
System returned to ROM by reload
System restarted at 15:14:33 UTC Wed Oct 14 2020
System image file is "bootflash:/asr1001x-universalk9.16.06.02.SPA.bin"
Last reload reason: PowerOn
License Type: Permanent
License Level: adventerprise
Next reload license Level: adventerprise
cisco ASR1001-X (1NG) processor (revision 1NG) with 6934953K/6147K bytes of memory.
Processor board ID FXS2047Q28G
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
6594559K bytes of eUSB flash at bootflash:.
0K bytes of WebUI ODM Files at webui:.
#show memory
                           Head             Total(b)         Used(b)          Free(b)      Lowest(b) Largest(b)
Processor 7F3519AEC010 7101257400 464165696 6637091704 5469154792 5469859828
lsmpi_io 7F3518E9E1A8 6295128 6294304 824 824 412
Hello
It may also be your ISP is summersing for you.
Rtrs nowadays support RR (route fresh) so suggest you to remove soft inbound configuration, This is very resource intensive to the rtr especially with a full RIB table
Kind Regards
Paul
balaji.bandi
Thank you, can you post below output  - i forgot to ask before :
sh ip bgp neighbor <> routes" and "sh ip bgp neighbor <> received-routes
BB
We have set up a default-route temporarily so as not to impact production
sh ip bgp neighbor XXX.XXX.XXX.169 routes
BGP table version is 1534986, local router ID is 194.XXX.XXX.XXX
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
t secondary path,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 0.0.0.0 XXX.XXX.XXX.169 0 0002 ?
Total number of prefixes 1
Hello @matou801 ,
from the previous show ip bgp summary we see that :
The system processed 815,609 prefixes in the past installing 815,605 of them.
However, the loading phase can last several minutes so  you should try again removing the inbound soft reconfiguration as suggested by Paul Driver.
You need to wait enough time to have all the routes loaded and installed if you check with show ip bgp summary in the middle of the update process you see a partial table.
You likely need to wait more then 5 minutes wait up to 15 minutes before telling your router is not able to keep all the routes.
@MHM Cisco World  no RT values are involved here this is addressa family ipv4 unicast and ipv6 unicast in global routing table as we can see from the configuration in first post in the thread.
Hope to help
Giuseppe
CE - PE using bgp
CE don’t need because it don’t use vrf
PE side use vrf,
if there are for example 100  but route-target under vrf toward this CE not include some other PE then
PE never send this route in to CE.
and hence even the PE have all route CE don’t have same number.
now he must check with PE route target and to be more clear he can simply check if route missing is for certain Other CE.
Hello
@MHM Cisco World
I would say its not for the customer-CE rtr to check for RT etc..
if he suspects he is missing routes he should query his ISP as he will not have any visibility to any vrf
Kind Regards
Paul
Here are the logs of the first attempt, we see that the tables are announced, but after 10-15 minutes we stopped
balaji.bandi
on what basis you have come to this routes "but after 5 minutes I only have 455,000 routes added to my router."
other question do you really need full routing table ? if you have only 1 exit point  ?
BB
Hello BB,
We put a full view, because we will have two ISP tomorrow
Hello
Even with two egress paths you wouldn’t require a full rib table
I agree  with @balaji.bandi @ what is the reason for a full internet table - You could have the isps to send partial routes or even just default routes or both and you can apply bgp attributes to specify which egress is preferred
Kind Regards
Paul
