BGP Global RIB vs Adj-RIB-Out
hfakoor222
Now in the snippet below step 5 mentions "Install the best-path route into the global RIB, process outbound rules... then advertise to BGP peers"
My question is this statement referring to the best route being advertised from the global-RIB or the routes in the Adj-OUT table being advertised? I'm assuming it is the global RIB.
2 Accepted Solutions
this my note for Loc-RIB and Adj-RIB-Out.
First Thanks to @paul.driver  for his comment.
and @hfakoor222 to be 100 % sure that happened I do small LAB
R1-R4-R2 AS 100
R2-R3  AS 200
LO 1.1.1.1 in both R1 and R4
show ip bgp route <- receive the LO route from R1
show ip bgp route<- receive the LO route from R4
show ip route global
apply
route-map OUT
match permit only LO route that next-hop is R4
NOW when apply
 route-map OUT
and check
show ip route
R3 advertised-route
I see that there is NO route and that make sense since
Global RIB contain only best path.
best path is point to R1 not R4
I apply
route-map OUT
to filter
the LO route is missing
because
route-map OUT
apply to global RIB not Local-RIB receive from R1/R4 i.e. after best path select not before that.
and hence the Adj-RIB-out is show "0" route.
so I hope this lab is answer your Q.
7 Replies 7
hfakoor222
I read 3 pages further, it states the Sdj-RIB-Oyt table routes are being advertised. I guess this is done so the neighbor router knows of other poterntial routes.
see my comment above for your Q.
paul.driver
Hello
Yes it is the global route table (GRT)
Hello
Kind Regards
Paul
R1-R4-R2 AS 100
R2-R3  AS 200
apply
route-map OUT
NOW when apply
 route-map OUT
and check
show ip route
R3 advertised-route
I apply
route-map OUT
to filter
because
route-map OUT
