ISR 4331 SFP
pbelletty
Hi Folks
Wonder if you could help have an ISR 4331 with an SFP (SFP-GB-GE-T) in interface G0/0/2.
It is set for auto negotiation and negotiates to 100M/Full duplex to an ADVA NTE. Although the interface comes up I am seeing CRC errors. The circuit that the interface is connected to is clean. The problem is related to the ISR/SFP.
Strangely if I connect a router directly to the ISR with auto negotiation the link comes up at 1G/Full with no CRC errors.
I have checked out the SFP and it appears that I cannot find anything on the Cisco website in respect of SFP-GB-GE-T only SFP-GE-T. Does anyone know what the GB means or what the difference is between the two types of SFPs.
Could anyone suggest what the issue may be?
Look forward to hearing from you.
Phil
2 Accepted Solutions
jvillareal
I have encountered this issue with various ADVA NTE models (114Pro, 116Pro).
All of the testing I have performed with them indicates that they just don't like running an optical SFP at 100-Full.
Thanks for the reply. That is interesting to know.  Appreciated.
14 Replies 14
balaji.bandi
SFP-GE-T  (GLC-T)- This is the Cisco SFP i have used and works as expected GE -Gigabit Ethernet ( Maybe GB Gigabit - with rd Party)
what is the service provider delivery? 100MB or Gigabit?
SFP-GB-GE-T  - From cisco? never seen or are we missing some information here?
try below command :  (this will flap the interface to re-negotiate, if you doing from internet, you may lost connection) so try from lan side
no negotiation auto
it also good to post-
show interface gig x/x
  and
show version
to understand the issue better.
BB
Hi BB
Thanks for the reply. Don't have access to the router at the moment but will provide the details as suggest as soon as I can.
Phil
what ADVA NTE are you connecting to ?
Thanks for replying.
Good question but sorry I don't know. It is a BT Openreach circuit.
Leo Laohoo
Post the complete output to the command
sh interface Gi0/0/02.
The output of
show interface g0/0/2
is
GigabitEthernet0/0/2 is up, line protocol is up
Hardware is ISR4331-3x1GE, address is 00f2.8bd0.3c72 (bia 00f2.8bd0.3c72)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 131/255, txload 1/255, rxload 1/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not supported
Full Duplex, 100Mbps, link type is auto, media type is T
output flow-control is off, input flow-control is off
Last input never, output 00:00:01, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
41433 input errors, 41433 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
22898 packets output, 1466538 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 unknown protocol drops
5 lost carrier, 0 no carrier, 0 pause output
And show version
Cisco IOS XE Software, Version 03.13.04.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 05-Oct-15 11:24 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ce1b-uk-tflbus-000-GBLON uptime is 14 hours, 12 minutes
Uptime for this control processor is 14 hours, 13 minutes
System returned to ROM by reload at 15:33:41 UTC Thu Nov 18 2021
System image file is "bootflash:/isr4300-universalk9.03.13.04.S.154-3.S4-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appx appxk9 RightToUse appxk9
uc uck9 RightToUse uck9
security securityk9 RightToUse securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1687137K/6147K bytes of memory.
Processor board ID FDO1951A476
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
@pbelletty wrote:
reliability 131/255
F*************************************************************************ck!
I have never seen a Layer 1 fault that bad before.
Change the patch cable and try again.
Yes the interface is clocking up CRC errors. We have swapped the cables. In fact we disconnected the cable from the ISR and connected it to a test router with a GigE RJ45 interface and we had a clean connection so I can only assume that it is the SFP/router.
The SFP is SFP-GB-GE-T however I was unable to find this model on Cisco site. There is however SFP-GE-T. I was wondering what the difference is between these SFPs.
By the way we have swapped out SFPs but not sure what modules were used.
GLC-T or GLC-TE would be sufficient.
Can you move the SFP to a different port and see if the results are the same?
hi,
you need to ask your ISP what's their port speed/duplex and hard code the same on your 4331 port.
can you try below:
int g0/0/2
 no negotiation auto
 speed 100
 duplex full
 shut
 no shut
I have managed to implement a workaround for the problem by swapping the SFP interface for a RJ45 interface on the router. I could not get the SFP  interface to work with the ADVA NTE. I tried the SFP-GB-GE-T and Cisco GLC-T.
The ADVA NTE (FSP 150-GE102Pro) which terminates the Openreach circuit is set up for auto negotiate at Full/100M.
Using the GLC-T the interface would not come up.
SFP-GB-GE-T is not a Cisco module. It is a compatible SFP made by FS (https://www.fs.com/products/11773.html?attribute=945&id=284134)
Apparently there are two types with the same product name, 10/100/1000M and 1000M. If you insert the 1000M  module then the link comes up at Full/100M on the ISR but CRC errors are seen. If the former is used it also comes up as Full/100M but without any CRC errors. Unfortunately it would not pass any frames.
So we could not get the SPF interface to work with the ADVA NTE and had to use the RJ45 interface on the router.
Hope this helps anyone else that encounters the same problem.
All the best,
Phil
Hello
Have you tried hardcoding the interface?
int x/x
no negotiation auto
speed 100
duplex full
Kind Regards
Paul
jvillareal
