BGP idle due to No outgoing interface
ICANG
Hi all,
On Nexus switch bgp stuck in idle due to "no outgoing interface". There is a ping to bgp peer (VIP IP). BFD to VM that's in front of the peer is UP. What could be the issue ? Debug logs are below
BGP state = Idle (No outgoing interface)
Debug
(ABC) EVT: 10.115.12.8 remote iod 0 skip resolving l3 addr
(ABC) EVT: 10.115.12.8 peer connection retry timer expired
(ABC) EVT: Single hop EBGP peer 10.115.12.8 not directly attached (active), outbound interface Unknown
(ABC) EVT: Starting timer (5 sec 0 nsec) for 10.115.12.8 connection retry
Routing
10.115.12.8/32, ubest/mbest: 1/0
*via 10.115.17.2, Vlan1650, [1/0], 21:18:13, static
Ping to VIP IP
--- 10.115.12.8 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.45/0.526/0.741 ms
Giuseppe Larosa
Hello @ICANG ,
it is an eBGP peer so the default TTL for BGP packets is 1
you need to add under router bgp
neighbor 10.115.12.8 ebgp-multihop 2
Note:
a similar comand is needed also on the EBGP peer
Hope to help
Giuseppe
Giuseppe Larosa
Hello @ICANG ,
Note:
Hope to help
Giuseppe
balaji.bandi
Personally  top of my head i do not believe that work with VIP IP - you need to peer with L3 Interface IP .
change the peer IP L3 IP (instead of VIP ?)
BB
