07-12-2020 03:40 AM
Hello.
I am trying to create a simple set up for BGP.
R1 to R2 will use remote as 3
R2 to R3 will use rmeote as 89
Things look fine between R1 and R2.
But between R2 and R3 i get these messages - see attached file.
Why does it behave like this?
It should work fine, as I see.
Best regards!
Solved! Go to Solution.
07-12-2020 11:06 AM
> If I use BGP remote-as 3 on R3, then it does speak with R2. But if I use another remote-as, it does not work.
This is normal behavior. The remote-as you configure on the neighbor statement for R2 on R3 needs to match the AS number configured on R2, which is 3.
07-12-2020 04:58 AM
Look at the document and try the option as suggested :
if still not working, post complete router configuration look and advise here.
07-12-2020 08:20 AM
Hello.
Thank you for your replay.
I have tried it, but it does not seems to help.
I have even reinstalled R3.
Attached you may find the configuration of the routers.
Best regards.
07-12-2020 09:36 AM
is this test Lab?
do you have reachability between R2 and R3- is the right interface connected each other
can you post-show CDP neigh from both R2 and R3
ping also from both the routers ? from R2: ping 192.168.103.1023from R3: 192.168.103.102
07-12-2020 10:10 AM
Hello.
This is a lab. yes, the routers can ping each other, R1 to R2 and R2 to R3.
I can ssh from R1 to R2 and from R2 to R3.
Best regards!
07-12-2020 11:06 AM
07-13-2020 08:27 AM
I got it.
Thank you.
