BGP Incorrect netowrk or mask
hfakoor222
trying to get loopback addresses to advertise
*Mar 1 00:44:04.715: %SYS-5-CONFIG_I: Configured from console by console
R2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R2(config)#router bgp 500
R2(config-router)#network 192.168.2.1 mask 255.255.255.224
% BGP: Incorrect network or mask configured
R2(config-router)#network 192.168.2.65 mask 255.255.255.192
R2(config-router)#exit
R2(config)#do sh ip int br | inc Loopback
Loopback0 192.168.2.1 YES manual up up
Loopback1 192.168.2.65 YES manual up up
R2(config)#
R2#
loopback configs
interface Loopback0
ip address 192.168.2.1 255.255.255.224
ipv6 address FE80::2:3 link-local
ipv6 address 2001:DB8:ACAD:2000::1/64
end
interface Loopback1
ip address 192.168.2.65 255.255.255.192
ipv6 address FE80::2:4 link-local
ipv6 address 2001:DB8:ACAD:2001::1/64
end
don't see why it is not working....
Overall running-config
archive
log config
hidekeys
ip tcp synwait-time 5
interface Loopback0
interface Loopback1
interface FastEthernet0/0
ip address 10.1.2.2 255.255.255.0
duplex auto
speed auto
ipv6 address FE80::2:1 link-local
ipv6 address 2001:DB8:ACAD:1012::2/64
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 10.2.3.2 255.255.255.0
duplex auto
speed auto
ipv6 address FE80::2:2 link-local
ipv6 address 2001:DB8:ACAD:1023::2/64
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router bgp 500
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 10.1.2.1 remote-as 6500
neighbor 10.2.3.3 remote-as 300
neighbor 2001:DB8:ACAD:1012::1 remote-as 6500
neighbor 2001:DB8:ACAD:1023::3 remote-as 300
address-family ipv4
neighbor 10.1.2.1 activate
neighbor 10.2.3.3 activate
neighbor 2001:DB8:ACAD:1012::1 activate
neighbor 2001:DB8:ACAD:1023::3 activate
no auto-summary
no synchronization
exit-address-family
address-family ipv6
network 2001:DB8:ACAD:2000::1/64
network 2001:DB8:ACAD:2001::1/64
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
sp2720401
You are using the address of the interface... you should be using the network.
network 192.168.2.0 mask 255.255.255.224
network 192.168.2.64 mask 255.255.255.192
sp2720401
network 192.168.2.1 mask 255.255.255.255
network 192.168.2.65 mask 255.255.255.255
 only loopback will advertise not all sunbet when using 255.255.255.255
That only works if the version of IOS automatically creates a "local route" in the routing table. The correct way is to match the "connected route" or change the subnetting of the loopback interface to a /32 host address and use a /32 netmask in the network statement.
Hello
What is the reason you have loopback interfaces with non host ip addressing?
Kind Regards
Paul
