bgp inject-map
    I am trying to test bgp inject-map using gns3 and am facing some problem. I am using the following topology.
|R7 AS 1000|-----|R3 AS 1200|-----|R4 AS 1000|
R7 is sending some aggregate 172.16.0.0/16 to R3. I want to generate 172.16.9.0/24 along with aggregate and send to R4.
R3:
router bgp 1200
no synchronization
bgp log-neighbor-changes
bgp inject-map advert exist-map check
neighbor 10.1.2.4 remote-as 1300
neighbor 10.1.2.4 ebgp-multihop 2
neighbor 10.1.2.4 update-source Loopback0
neighbor 10.1.2.4 next-hop-self
neighbor 10.1.2.4 send-community
neighbor 10.1.2.7 remote-as 1000
neighbor 10.1.2.7 ebgp-multihop 2
neighbor 10.1.2.7 update-source Loopback0
no auto-summary
R3#show route-map advert
route-map advert, permit, sequence 10
  Match clauses:
  Set clauses:
    ip address (prefix-list) adver
    community no-export
  Policy routing matches: 0 packets, 0 bytes
R3#show ip prefix-list adver
ip prefix-list adver: 1 entries
   seq 10 permit 172.16.7.0/24
R3#
R3#
R3#show route-map check
route-map check, permit, sequence 10
  Match clauses:
    ip address prefix-lists: leanred
    ip route-source prefix-lists: source
  Set clauses:
R3#
R3#show ip prefix-list learned
ip prefix-list learned: 1 entries
   seq 10 permit 172.16.0.0/16
R3#show ip prefix-list source
ip prefix-list source: 1 entries
   seq 10 permit 10.1.2.7/32
R3#
R3#
R3#show ip bgp
BGP table version is 2, local router ID is 30.1.2.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 172.16.0.0       10.1.2.7                 0             0 1000 i
R3#
R4:
R4#show ip bgp
BGP table version is 6, local router ID is 40.1.2.1
*> 172.16.0.0       10.1.2.3                               0 1200 1000 i
R4#
As shown above, I am seeing only aggregate on R4, not specific. What could be wrong with my config? Your help is appreciated.
Balajee
5 Replies 5
Hello Balajee,
Not tested this but can you try perfoming the inject-map on R4 instead?
something like this:
R4
ip prefix-list NETWORK permit 172.16.7.0/24
ip prefix-list AGGREGATE permit 172.16.0.0/16
ip prefix-list R3 permit 10.1.2.3/24 ( i am asuming this is a 24 bit towards R3 from R4)
route-map EXIST permit 10
match ip address prefix-list AGGREGATE
match ip address prefix-list R3
route-map INJECT permit 10
match ip address prefix-list NETWORK
router bgp 1000
bgp inject-map INJECT exist-map EXIST
so if i am correct - this is telling the router to check if the 172.16.0.0/16 exists and  R3 is up then call the inject map and inject the 172.16.7.0/24
res
Paul
Kind Regards
Paul
milan.kulik
Level 10
Level 10
according to http://www.cisco.com/en/US/customer/docs/ios/12_2t/12_2t4/feature/guide/ftbgpri.html
your config looks correct.
I suppose sh ip bgp injected-paths does not show the  172.16.7.0/24 prefix withion the R3 BGP table?
I guess there might be some bug in your IOS?
Possibly bringing a trouble with this feature while using eBGP multihop?
What about trying to use a simple peering using interface IP addresses?
Or removing the  set community no-export command from your route-map?
BR,
Milan
Jose Jara
Level 3
Level 3
Hi Balajee,
I see two things in your config:
1.
  Match clauses:
    ip address prefix-lists: leanred --------------- it should be learned, the name of your prefix-list created
2.
  Match clauses:
  Set clauses:
    community no-export ---------------------------- it should be removed here, if you want to apply the no-export community to apply it for the eBGP neighbor, put a route-map in the outbound direction.
For verification you can use: show ip bgp injected-paths
Hope this telps,
Jose.
Ohhhhhh.....great catch. Stupid mistake from me. Thanks a lot and appreciate your help.
Balajee
Forgot to add....after making the changes suggested by you, it worked.
