bgp network backdoor
Kashish_Patel
Level 2
Level 2
I am not quite sure about "network <> backdoor" command in bgp. On one of our routers, we have
network 0.0.0.0 backdoor
network 10.0.0.0
network 192.168.0.0
Can somebody explain "network backdoor" in this context?
5 Replies 5
cadet alain
It means that this network will be advertised with an AD of 200 and so won't make it into the routing table as a BGP route if there is another protocol advertising  it with a better AD
Regards.
Alain
mahmoodmkl
Level 7
Level 7
in addition think of it lime this tht it used to prefer route learned from igp thn bgp
Jose Jara
Level 3
Level 3
it changes the administrative distance to 200. A common use is when you are learning a prefix via eBGP and via one IGP, therefore, it is going to be preferred via eBGP 20 is better than 110- OSPF, 115 IS-IS, 120 RIP or 90-170 EIGRP.
You would like to prefer the IGP route for whatever reason, then the backdoor could be useful here.
HTH,
Jose.
Hi Jose,
correct!
Plus the backdoor route is not advertised via BGP.
BR,
Milan
BGP backdoor feature is useful for modify the default routing  behavior of BGP for specific networks in situations where we wish to  route over a backdoor link, running some other normally less preferred  IGP.
Chamara
Dont forget to rate helpful posts
