BGP - invalid or corrupt AS path
Eric Snijders
Hi all,
We're trying to set up a eBGP connection between a Cisco C3850 (our side) and a Nexus 7000 (customer side).
First i got "mal-formatted" messages from the Nexus 7000. The Nexus side configured "dont-capability-negotiate" and now i'm getting the following error:
Nov  7 08:03:21.580: %BGP-3-NOTIFICATION: received from neighbor 172.24.254.168 3/11 (invalid or corrupt AS path) 7 bytes 40020402 01FFFF
Neighbor configuration for this one is configured as followed:
 neighbor 172.24.254.168 remote-as 65011
 neighbor 172.24.254.168 description eBGP XYZ
 neighbor 172.24.254.168 password 7 ABCDEFGHIJKLMNOP
 neighbor 172.24.254.168 version 4
 neighbor 172.24.254.168 next-hop-self
 neighbor 172.24.254.168 soft-reconfiguration inbound
 neighbor 172.24.254.168 prefix-list Prefix-XYZ in
 neighbor 172.24.254.168 prefix-list YXZ-Prefix out
Does anyone have a suggestion what we could try, i'm lost right now...
Thanks in advance!
Eric
Hello
neighbor 172.24.254.168 dont-capability-negotiate  <-- This is used when two peers have conflicting capabilities , but i don't see this applied?
Kind Regards
Paul
my first thought is, the line below is the culprit, can you take that out ?
--> neighbor 172.24.254.168 version 4
Hello
Kind Regards
Paul
Hi Paul,
You were right, i just applied dont-capability-negotiate to this neighbor and BGP is established. I thought that command only had to be applied to the sending side (in this case the peer), but it appears you need it on both sides.
Problem solved!
Thanks all!
Hello Eric
Glad it worked for you.
FYI - As the routers try to establish a peering they need to negotiate each other capabilities and if they cannot then they wnt establish
Example:
sh ip bgp neighbors | s Neighbor capabilities
 Neighbor capabilities:
    Route refresh: advertised and received(new)
    Four-octets ASN Capability: advertised and received   <------------------------- advertised and received means  both sides are supporting
    Address family IPv4 Unicast: advertised and received<------------------------- advertised and received means  both sides are supporting
    Multisession Capability:
    Route refresh: advertised <------------------------- Trying to negotiate with neighbor
    Four-octets ASN Capability: advertised <------------------------- Trying to negotiate with neighbor
    Address family IPv4 Unicast: advertised and received  <-------------------------Both sides are supporting
Applying neighbor x.x.x.x dont-capability-negotiate - negates this conflicting capability so allows peering
Kind Regards
Paul
