BGP ipv6 default route origination
grichardson661
My colleague and i are struggling to originate a IPv6 BGP default route from one of our core switches to an eBGP peer.
This is the configuration (below) we have tried and does work within GNS3 running the same IOS but it doesn't seem to work on our live environment.
router bgp XXXX
bgp router-id 1.1.1.1
bgp log-neighbor-changes
neighbor x:x:6:11::1 remote-as 65003
address-family ipv6
  network ::/0
  neighbor x:x:6:11::1 activate
  neighbor x:x:6:11::1 prefix-list 65003-out out
exit-address-family
ipv6 route ::/0 Null0
ipv6 prefix-list 65003-out seq 5 permit ::/0
When we reverse the above configuration, so we send a IPv6 Default BGP route from the customer to the core the above configuration works, however, the core see's the route as ::/8 not ::/0 (very strange). Has anybody seen this before? This doesn't make sense as on the customer infrastructure we can see ::/0 in the BGP table but on the core we see ::/8. We are thinking because the core is seeing the route as::/8 this is having an affect when we are trying to originate ::/0 from the core to the customer..
Maybe this is a bug but we're not sure. Anybody seen this before?
Cheers,
Hello
conf t
no ipv6 route ::/0 Null
no ipv6 prefix-list 65003-out seq 5 permit ::/0
router bgp XXXX
address-family ipv6
 no network ::/0
no neighbor x:x:6:11::1 prefix-list 65003-out out
neighbor x:x:6:11::1 default-originate
exit-address-family
clear bgp ipv6 unicast * soft
res
Paul
Kind Regards
Paul
Hi Paul, thanks for the response. We have tried that it doesn't work.
We have just found out the switch has a problem dealing with a bogus route ::/8 and the default route ::/0. If we drop ::/8 on the edge ::/0 appears in the routing table, if we permit ::/8 ::/0 drops out. We will be logging this with Cisco.
Thanks for your help anyway.
