Bgp IPV6 peering update loopbak
Hi guys,
i have a question for you. If it's possible of course.
I have some problems setting BGP in ipv6 environment. I have this sample configuration
Router:1
conf t
ipv6 unicast routing
router bgp 1
bgp router id 192.168.0.1
neighbor 2::2 update-source loopback 0
address family ipv6
neighbor 2::2 activate (loopback 0)
network 11::11/128 (loopback 1)
Router 2
conf t
router bgp 2
bgp router id 192.168.0.2
neighbor 1::1 update-source loopback 0
address family ipv6
neighbor 1::1 activate (loopback 0)
network 22::22/128 (loopback 1)
In Gns3 i test it with C7200 iso but don't work !!!
We can help me?
Best regards
13 Replies 13
First can you ping between router for ipv6?
Yes i ping all routers on serial with ipv6 address 2001:1::1/64 for the first router and 2001:1::2/64 for second router, but the bgp protocollo don't execute adjacency
Ok'
Neighbor <ipv6> remote-as xx
I dont see this command
You are right, I forgot to write it down. Sorry
No since as is different you and multi hop away you need
Neighbor <ipv6> ebgp multihop
Ok I try it and update
Sorry, dont work probably gns3 have a bug on ios on 7200
Can I see the config ? all config.
Do you ping from lo to lo
You need to use source in ping command
Router 1:
Building configuration...
Current configuration : 1879 bytes
version 12.2
hostname R1
logging queue-limit 100
ip subnet-zero
no ip icmp rate-limit unreachable
ip tcp synwait-time 5
no ip domain lookup
ip cef
ipv6 unicast-routing
mpls ldp logging neighbor-changes
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface Loopback0
no ip address
ipv6 address 1::1/128
interface Loopback1
no ip address
ipv6 address 11::11/128
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
serial restart_delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router bgp 1
no synchronization
bgp router-id 192.168.0.1
bgp log-neighbor-changes
neighbor 2::2 remote-as 2
neighbor 2::2 update-source Loopback0
no auto-summary
address-family ipv4 multicast
no auto-summary
no synchronization
exit-address-family
address-family ipv6
network 11::11/128
exit-address-family
address-family ipv4
no neighbor 2::2 activate
no auto-summary
no synchronization
exit-address-family
ip classless
no ip http server
no ip http secure-server
no cdp log mismatch duplex
call rsvp-sync
mgcp profile default
dial-peer cor custom
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Router 2:
version 12.2
hostname R2
ip subnet-zero
no ip domain lookup
ip cef
interface Loopback0
no ip address
ipv6 address 2::2/128
interface Loopback1
no ip address
ipv6 address 22::22/128
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
ipv6 address 2001:1::2/64
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router bgp 2
no synchronization
bgp router-id 192.168.0.2
neighbor 1::1 remote-as 1
neighbor 1::1 update-source Loopback0
no auto-summary
no auto-summary
no synchronization
exit-address-family
address-family ipv6
network 22::22/128
exit-address-family
address-family ipv4
no neighbor 1::1 activate
no auto-summary
no synchronization
exit-address-family
ip classless
no ip http server
call rsvp-sync
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
The issue its multihope setting dont work !!!
As I mention in my first comment'
Where is static or igp route between two routers? The loopback must be appear in rib then you can use bgp'
lo must ping to other lo
The bgp not like other igp' it need first ip reachability between two peers.
Thank you works correctly!!!IGP with OSPFv3
You are so welcome
Have a nice day
MHM
