Configure DHCP Snooping
Ian Dewar
Can you help with this lab?
Configure Sw1:
• Enable DNCP Snooping for VLAN 10
• Disable DHCP Option-82 data insertion
• Enable DHCP Snooping MAC address verification
• Enable trusted interfaces
14 Replies 14
In which step you stop
Ian Dewar
Is this correct?
Nope not need all this'
1-As your request disable op-82
No ip dhcp snooping inforomation
2- enable dhcp snooping
Ip dhcp snooping
Ip dhcp snooping vlan x
3- config trust
Interface x/x
Ip dhcp snooping trust
4- verify mac' if you face issue with dhcp snooping then remove this command
Ip dhcp snooping verify mac-address
Ian Dewar
Like this:
Conf t
Ip dhcp snooping vlan 10
no Ip dhcp snooping information
Except this command
Above command must add under interface of SW direct content or point to DHCP server '
Note:- for SW1 this command must add under interfac e0/1 and e0/2 only.
It not config in global
Ian Dewar
Like this:
Conf t
Interface
Nop' check above my comment
Ian Dewar
Like this:
Conf t
Interface range e0/1-2
  This lab on PacketTracer works fine.
Not sure which simulator you are using and we must consider some limitation on the PacketTracer.
I think he is new reading this topic'
Can you help him and give him link of packet tracer new versions.
He need software to test the config.
MHM
Ian Dewar
I tried opening the file and got this:
How do i update to this version?
I believe you need to download a new one from cisco site.
But you can make it work on yours.
 Put the interface to the router as trust.
On the botton switches put both trunk and
PC port as trust ports.
Conf t
Interface X
On the Upper switch you need to add the commamd on the trunk also
It shoud be enouth.
Hello
Dhcp snooping should be applied on sw1,2,3
ip dhcp snooping
ip dhcp snooping vlan 10
Disabled by default
Globally enabled
ip dhcp snooping verify mac-address
Trusted interfaces  applied to - Sw1-2  (eth0/1, eth0/2)  Sw3 (eth0/1,eth0.2, eth1/0)
Kind Regards
Paul
