Cisco Modeling Labs - CAT9300
Timothy Patrick
Hello, I  have been playing around with both CAT9300V models in CML. I  am trying to create a L3 port and setup eigrp neighbor between an IOSv device. when I  create the L3 port I  see the port in an UP UP state but I  can not ping across to the other side
CAT9300V ---------- IOSv
10.252.247.6/30---------10.252.247.5/30
I  am able to do a
show cdp
neighbor from the IOSv side
Device ID Local Intrfce Holdtme Capability Platform Port ID
Switch Gig 0/3 169 R S I C9KV-UADP Gig 1/0/1
but nothing from the 9300 side
Timothy Patrick
yes the port is up/up on both sides but I  am unable to ping from 9300 to IOSv.
I  switched it from 9300V Doppler to 9300V SiliconOne and it seems to work now. not sure what was going on
M02@rt37
Hello @Timothy Patrick,
When you say "but nothing from the 9300 side" you mean that you don't have cdp information on that equipement? 9300's port is UP/UP? The IP adress and mask configured are the good one?
Best regards
Timothy Patrick
Are the CAT9300V images supported by DNAC for services like SDAccess and PNP?  I cannot find anything in the support matrix as of today, and haven't attempted it yet.
