BGP - loopback addresses und ip address not reachable after next hop
beta_admin66
I built a small lab with 5 routers. On some routers I have distributed the loopback addresses on the network.
R1:
router bgp 100
bgp log-neighbor-changes
neighbor 10.1.1.2 remote-as 200
neighbor 10.1.2.2 remote-as 300
R1#show ip route
B 4.4.4.4 [20/0] via 10.1.1.2, 00:01:24
6.0.0.0/32 is subnetted, 1 subnets
B 6.6.6.6 [20/0] via 10.1.2.2, 00:01:24
R2:
router bgp 200
bgp router-id 2.2.2.2
neighbor 10.1.1.1 remote-as 100
neighbor 10.24.1.2 remote-as 400
R3:
router bgp 300
neighbor 10.1.2.1 remote-as 100
neighbor 10.36.1.2 remote-as 400
R4:
router bgp 400
bgp router-id 4.4.4.4
network 4.4.4.4 mask 255.255.255.255
neighbor 10.24.1.1 remote-as 200
R6:
router bgp 400
network 6.6.6.6 mask 255.255.255.255
neighbor 10.25.1.1 remote-as 400
neighbor 10.36.1.1 remote-as 300
But I can not ping the loopback adresses.
Can you help me?
Thanks.
This not work' R1 know LO of R4/R6
But are R4/R6 dont know any IP from R1 ?
So the R1 use ip unknown from R4/R6 and hence the ping drop
Simple solution is redistrubte connect in all router.
MHM
While R1 has the route to the 6.6.6.6 address the R6 router doesn't have any way to get back to R1. You need to advertise a network from R1 into the BGP domain to get propagated to R6. Then when you issue a ping make sure you ping with a source address of the loopback as that's all that's reachable to the BGP peers.
-David
Hello
Assumption is your bgp peering is via directly attached interfaces?
Aslo it looks like you have incomplete ibgp peering in AS400, R4-R6 requires ibgp peering between each other so the bgp reachability information pertaining to a next hop is updated so each AS400 ebep/ibgp rtr will advetise itself as a nexthop for bgp preifxes external to AS400
R4
neigbour <r6> next-hop-self
R6
neigbour <r4> next-hop-self
Kind Regards
Paul
