BGP Neighbours not forming
I have to iBGP peers that are not forming. I can't seem to find why.... I have added IGP underlay but they can't reach the loopback addresses I have set the neighbors too. They can ping each other but unable to ping their loopback addresses.
XR1:
router bgp 65001
bgp confederation peers
65002
bgp confederation identifier 100
bgp router-id 10.1.1.1
address-family ipv4 unicast
neighbor 10.2.2.2
remote-as 65001
update-source Loopback0
XR2:
router bgp 65001
bgp router-id 10.2.2.2
neighbor 10.1.1.1
remote-as 65001
update-source Loopback1
Martin L
you need to reach IP of loopback x from IP of loopback y; for testing, use ping x source y
add static routes or advertise them into ospf -if ping fail;
Regards, ML
**Please Rate All Helpful Responses **
ebgp-multihop [ ttl-value ] <<- this need in both router **
also make sure that LO is reachable in both routers
MHM
The is an iBGP lab. I am used to having all the routers loopbacks in the routing table so not sure if its a bug running on EVE-NG
MHM
Martin L
Regards, ML
