BGP New network range not working
ahpark78
I have 4 routers running BGP through megapop circuit.2 Routers from Remote A, which acts as redundancy connecting to Remote B, which got another 2 routers as redundancy also.
A new network range 192.168.1.0/24 added at Remote A's Routers.
But seems like the Routers at Remote A's BGP not able to advertise to Remote B's Routers.
What have i done wrong? I have did a clear ip bgp * on the remote site A , to advertise the new network but to still no avail.
Need help urgently. Thanks..
ken
5 Replies 5
royalblues
Level 10
Level 10
Hi Ken,
Do u see the route installed in the BGP route table. please check by issuing sh ip bgp
BGP does not advertise a network if it does not find a corresponding valid route in the IGP routing table.
so make sure you have a route in the IGP route table for the subnet you are advertising.
Also posting your configs would help
HTH, rate if it does
Narayan
Hi Narayan,
Thanks for your input. Have done Sh ip bgp,
and the routes are pointing to the right destination.
eg:
the 192.168.1.0/24 will need to push to 172.16.1.196 which is able to trace from Routers at remote A.
Is just that can;t able to trace to 192.168.1.0/24 from the remote B Routers, it can't go to another hop. It goes * * *.
whats next follow-up action that i need to check?
thanks,
ken
Sorry, just to confirm.
Did a "clear ip bgp" on the routers at Remote A which going to advertise new network range 192.168.1.0/24. Is that correct??
Or i should do clear ip bgp at Remote B routers instead??
thanks again.
can you post the outputs of sh ip bgp, sh ip route for all the routers
Narayan
Thanks Narayan.
The problem actually was solved. It was due to the access-list of the route-map that applies on the bgp. Once the network range is permitted under the access list, it works like a charm..:D thanks for all your input..
ken
