BGP Null 0
sk82
I see a route to a specific destination which says it is known via BGP type, locally generated - directly connected, via Null0.
I can also see aggregate-address to specific route with a wider range of /16 with the attribute-map configured.
What does this mean ?
there are two approach to summary prefix in BGP
1- use summary address to null0 and advertise this summary under BGP
2- use aggregate address under BGP
there is no different which approach you use but it common that engineer use null0 summary address because it so easy
MHM
Giuseppe Larosa
Hello @sk82 ,
a static route with outgoing interface null0 can be used in combination with a network command under BGP to create an aggregate.
All packets with a destination not matching a more specific prefix will be silently discarded  ( null0 = bin)
The more modern way to create an aggregate in BGP is to use the aggregate-address command.
For the aggregate-address to work a component route must be in the BGP table, if this component route is a route to null0 this route will never disappear and the aggregate-address is always advertised.
Hope to help
Giuseppe
