OTV on Catalyst 8000
MASO
I appreciate your help with the following case.
Our client has a legacy OTV network operating between its DCs and requires replacing the equipment of its main DC. I found that currently the only devices that support OTV are the Catalyst 8300/8500.
¿Can Catalyst 8300/8500 devices operate as 100% OTV Edge? ¿Do these devices have any limitations about OTV?
¿Are Catalyst 8300/8500 devices 100% interoperable in OTV with Nexus 7000 and ASR 1000 devices?
Thank you very much in advance for your help.
DC and GW of OTV I think you can use N9K it support OTV.
MHM
Hi NMH
Ok. I will review it. Thanks for your help.
MS
balaji.bandi
check only supported devices :
https://www.cisco.com/c/dam/en/us/products/collateral/switches/nexus-7000-series-switches/guide_c07-728315.pdf
Cat8K platform more of SD-WAN more featured, you can use for VXLAN - EVPN if you like to use.
BB
hi
Thanks BB. I'll check it.
MS
