BGP over IPsec between Cisco and Palo Alto (Multiple VRF's)
If I have Site A and Site B:
Site A has Border switch that sending prefixes over eBGP peering and multiple eBGP peerings for separate VRFs to the Cisco Routers and that Cisco Router connected via dark fiber with Site B FW (lets say palo alto)
What will be the approach to send all site A prefixes to Site B FW over the BGP with IPsec and making sure that FW will receive VRF prefixes as well, do we need to create a separate Tunnel for each VRF or we can use one Tunnel and send all VRF prefixes to FW by leaking them into the global routing table of Cisco route at site A ?
11 Replies 11
Hello!
I would configure MP-BGP which will enable you to forward multiple VRFs. Take a look into this.
https://docs.paloaltonetworks.com/pan-os/9-1/pan-os-admin/networking/bgp/mp-bgp
BR
****Kindly rate all useful posts*****
Torbjørn
You would need one tunnel per VRF, leaking everything into global routing for this is not a good solution. An alternative would be to do something like MPLS over GRE but this is not likely to be supported on your firewall: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_l3_vpns/configuration/xe-17/mp-l3-vpns-xe-17-book/mpls-vpn-l3vpn-over-gre.html#concept_61CDDF029C684AD29F6F059568B1EA54
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
rais
Level 7
Level 7
Does it need be global routing table on the Cisco? How about a FW-VRF on the Cisco that imports all exportable routes and does dynamic routing to PA?
I need to create an IPsec tunnels, so I need to understand the approach if I need to create a separate tunnels for each VRF BGP peering or I can use some kind of universal tunnel between sites and exchange that VRF prefixes over it
In my scenario I will receive only default route from site B Firewall
VPNv4 is solution if you multi VRF
note:- VPNv4 config in global not in any VRF
MHM
Does it mean I need create an IPsec tunnel for each VRF BGP peering between Site A and Site B ?
Sorry I was busy'
Can you confirm if this issue solve or not?
I want to run lab for you but if it already solved so no need to do that.
MHM
No, not through the one Tunnel, I assume I will need to do it with multiple Tunnels for each VRF between Site A and Site B
I run lab and I success advertise the prefix between vrf but I face issue in label.
My failed lab was
tunnel in global and run mpls in tunnel
VPNv4 run between tunnel IP in global' and do vrf target import/export'
Just want to solve mpls label.
MHM
Hello
can you post a topology diagram
Kind Regards
Paul
So basically between Borders there is iBGP, between Borders and Fusion eBGP, between Fusion's iBGP, between Fusion routers and Palo Alto - eBGP, I have tunnel IPsec and BGP over it between Fusion routers and Palo in Global RIB, there is also VRF's stretched from Borders to Fusion and from Fusion routers to Palo, on Palo side its one Virtual router (i.e on VRF) and its getting prefixes per global table and per VRF, so I wonder I can export VRF prefixes on Fusion router to Global table and from there export it to Palo Alto through my BGP IPsec peering, is it best approach or I need to create separate VRF IPsec BGP peerings from Fusion routers to Palo  for each VRF and send prefixes separately ?
