BGP over L3 problem
MohammadSalih
hi everyone,
i have to establish iBGP connection between the CSR towards the edge routers like (126,101,107,136,14,40)
i have more than one service provider towards the edges and the BGP connections is normally established.
the CSR reach to all Edge routers normally.
i already make the CSR Route-reflector to Readvertise the routes.
all router learned the routes normally but when i try to ping from one site (edge) to another, the host unreachable
example :
126#sh ip bgp
Network Next Hop Metric LocPrf Weight Path
*>i 20.20.14.0/24 10.120.98.17 0 100 0 i
*>i 20.20.40.0/24 10.120.98.17 0 100 0 i
*>i 20.20.101.0/24 10.120.98.17 0 100 0 i
*>i 20.20.107.0/24 10.120.98.17 0 100 0 i
*> 20.20.126.0/24 0.0.0.0 0 32768 i
*>i 20.20.136.0/24 10.120.98.17 0 100 0 i
*>i 172.19.255.254/32 10.120.98.17 0 100 0 i
126#ping 20.20.14.254 source lo0
Sending 5, 100-byte ICMP Echos to 20.20.14.254, timeout is 2 seconds:
Packet sent with a source address of 20.20.126.254
Success rate is 0 percent (0/5)
_______________
but the WIMAX Service provider is work fine because the connection between CSR and the edge(14,40) is L2
14#sh ip bgp
*> 20.20.14.0/24 0.0.0.0 0 32768 i
*>i 20.20.40.0/24 192.168.29.100 0 100 0 i
*>i 20.20.101.0/24 192.168.29.100 0 100 0 i
*>i 20.20.107.0/24 192.168.29.100 0 100 0 i
*>i 20.20.126.0/24 192.168.29.100 0 100 0 i
*>i 20.20.136.0/24 192.168.29.100 0 100 0 i
*>i 172.19.255.254/32 192.168.29.100 0 100 0 i
14#ping 20.20.40.254 source lo0
Sending 5, 100-byte ICMP Echos to 20.20.40.254, timeout is 2 seconds:
Packet sent with a source address of 20.20.14.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/3/5 ms
_______________
the problem is the L3 provider (IZFN and VSAT)
_______________
the configuration:
CSR
interface Loopback0
ip address 172.19.255.254 255.255.255.255
interface GigabitEthernet1
no ip address
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet1.29
encapsulation dot1Q 29
ip address 192.168.29.100 255.255.255.0
interface GigabitEthernet1.30
encapsulation dot1Q 30
ip address 192.168.30.100 255.255.255.0
interface GigabitEthernet1.98
encapsulation dot1Q 98
ip address 10.120.98.17 255.255.255.0
interface GigabitEthernet1.172
encapsulation dot1Q 172
ip address 172.22.8.6 255.255.255.0
router bgp 65001
bgp log-neighbor-changes
bgp listen range 192.168.0.0/16 peer-group WIMAX
bgp listen range 172.22.0.0/16 peer-group VSAT
bgp listen range 10.120.0.0/16 peer-group IZFN
network 172.19.255.254 mask 255.255.255.255
neighbor IZFN peer-group
neighbor IZFN remote-as 65001
neighbor IZFN route-reflector-client
neighbor IZFN next-hop-self all
neighbor WIMAX peer-group
neighbor WIMAX remote-as 65001
neighbor WIMAX route-reflector-client
neighbor WIMAX next-hop-self all
neighbor VSAT peer-group
neighbor VSAT remote-as 65001
neighbor VSAT route-reflector-client
neighbor VSAT next-hop-self all
ip route 10.120.0.0 255.255.0.0 10.120.98.1
ip route 172.22.0.0 255.255.0.0 172.22.8.1
ip route 192.168.29.0 255.255.255.0 192.168.29.254
ip route 192.168.30.0 255.255.255.0 192.168.30.254
ASR-1000#sh ip bgp
*>i 20.20.14.0/24 192.168.29.200 0 100 0 i
*>i 20.20.40.0/24 192.168.30.200 0 100 0 i
*>i 20.20.101.0/24 10.120.101.200 0 100 0 i
*>i 20.20.107.0/24 10.120.107.200 0 100 0 i
*>i 20.20.126.0/24 10.120.126.200 0 100 0 i
*>i 20.20.136.0/24 172.22.9.200 0 100 0 i
*> 172.19.255.254/32 0.0.0.0 0 32768 i
 126
 interface Loopback0
ip address 20.20.126.254 255.255.255.0
interface Ethernet0/0
ip address 10.120.126.200 255.255.255.0
router bgp 65001
network 20.20.126.0 mask 255.255.255.0
neighbor 10.120.98.17 remote-as 65001
ip route 10.120.98.0 255.255.255.0 10.120.126.1
101
interface Loopback0
ip address 20.20.101.254 255.255.255.0
ip address 10.120.101.200 255.255.255.0
router bgp 65001
network 20.20.101.0 mask 255.255.255.0
ip route 10.120.98.0 255.255.255.0 10.120.101.1
107
interface Loopback0
ip address 20.20.107.254 255.255.255.0
ip address 10.120.107.200 255.255.255.0
router bgp 65001
network 20.20.107.0 mask 255.255.255.0
ip route 10.120.98.0 255.255.255.0 10.120.107.1
136
interface Loopback0
ip address 20.20.136.254 255.255.255.0
ip address 172.22.9.200 255.255.255.0
router bgp 65001
network 20.20.136.0 mask 255.255.255.0
neighbor 172.22.8.6 remote-as 65001
ip route 172.22.0.0 255.255.0.0 172.22.9.1
14
interface Loopback0
ip address 20.20.14.254 255.255.255.0
ip address 192.168.29.200 255.255.255.0
router bgp 65001
network 20.20.14.0 mask 255.255.255.0
neighbor 192.168.29.100 remote-as 65001
ip route 192.168.0.0 255.255.0.0 192.168.29.254
40
interface Loopback0
ip address 20.20.40.254 255.255.255.0
ip address 192.168.30.200 255.255.255.0
router bgp 65001
network 20.20.40.0 mask 255.255.255.0
neighbor 192.168.30.100 remote-as 65001
ip route 192.168.0.0 255.255.0.0 192.168.30.254
____________
all edges have these route in routing table
sh ip route bgp
Gateway of last resort is not set
20.0.0.0/8 is variably subnetted, 7 subnets, 2 masks
B 20.20.14.0/24 [200/0] via 192.168.30.100, 00:21:53
B 20.20.101.0/24 [200/0] via 192.168.30.100, 00:21:53
B 20.20.107.0/24 [200/0] via 192.168.30.100, 00:21:53
B 20.20.126.0/24 [200/0] via 192.168.30.100, 00:21:53
B 20.20.136.0/24 [200/0] via 192.168.30.100, 00:21:52
172.19.0.0/32 is subnetted, 1 subnets
B 172.19.255.254 [200/0] via 192.168.30.100, 00:21:53
Giuseppe Larosa
Hello @MohammadSalih ,
you need to deploy an overlay network for example p2p GRE tunnels from hub router to all the remote sites.
Your connectivity is not working because the Service Providers that are working at Layer3 are not aware of each site LAN IP subnet so they cannot route packets with this kind of destination addresses.
Hope to help
Giuseppe
This LO0 is known by 20.20.14.x router?
