BGP PRIMARY AND SECONDARY PATH
ajay kondapalli
                   In my Network thtere are 2 routers Router A and Router B.which are configured    whith IBGP  relation and  these two routers are connected
to 2 different ISPs with EBGP relation.my requrement is that  router A should work as  primary and Router B work as secondary path . so here what are the possible filds to be consider to achieve primary and secondry.
    Ajay
Reza Sharifi
You can use local pref or AS path prepend:
have a look at this doc:
http://blog.ioshints.info/2008/02/bgp-essentials-as-path-prepending.html
