bgp problem:
att-sgcops
Level 3
Level 3
4 routers as u can see from the map, only BGP routing protocol trun on. I advertise 22.22.22.0/24 from R2:
_____________________________________
R1#sh run | b router bgp
router bgp 100
no synchronization
bgp log-neighbor-changes
neighbor 12.12.12.2 remote-as 200
neighbor 41.41.41.4 remote-as 100
no auto-summary
R2#sh run | b router bgp
router bgp 200
network 22.22.22.0 mask 255.255.255.0
neighbor 12.12.12.1 remote-as 100
neighbor 23.23.23.3 remote-as 300
R3#sh run | b router bgp
router bgp 300
no synchronization
neighbor 23.23.23.2 remote-as 200
neighbor 43.43.43.4 remote-as 100
no auto-summary
R4#sh run | b router bgp
router bgp 100
no synchronization
neighbor 41.41.41.1 remote-as 100
neighbor 43.43.43.3 remote-as 300
no auto-summary
I found R2 advertised this network to R1 and R3, and R1 and R4 advertised it each other, but R3 advertise it to R4, why R4 not advertised it back to R3 as it did to R1?
____________________________________________________________
R1#sh ip bgp 22.22.22.0
BGP routing table entry for 22.22.22.0/24, version 2
Paths: (2 available, best #2, table Default-IP-Routing-Table)
Advertised to update-groups:
43.43.43.3 (inaccessible) from 41.41.41.4 (33.33.33.36)
Origin IGP, metric 0, localpref 100, valid, internal
200
12.12.12.2 from 12.12.12.2 (22.22.22.22)
Origin IGP, metric 0, localpref 100, valid, external, best
______________________________________________________________
R4#sh ip bgp 22.22.22.0
Paths: (2 available, best #1, table Default-IP-Routing-Table)
43.43.43.3 from 43.43.43.3 (140.231.116.49)
Origin IGP, localpref 100, valid, external, best
200
12.12.12.2 (inaccessible) from 41.41.41.1 (20.20.20.1)
R3#sh ip bgp 22.22.22.0
Paths: (1 available, best #1, table Default-IP-Routing-Table)
23.23.23.2 from 23.23.23.2 (22.22.22.22)
_______________________________________________________________
What you need to note is that BGP only advertises routes that are in the routing table. A BGP learnt prefix that is not the best route (hence not in the routing table) will not be advertised. The same also applies with BGP learnt prefixes that are inaccessible.
The note also that routes learnt from exrernal peers are advertised to all peers, internal and external. Routes learnt from internal peers are advertised only to external peers.
In the first situation. R4 recieves the route from 2 sources, one from R1 and the other from R3. The one from R1 has its next-hop inaccessible, it therefore cannot be entered into the routing table. The best route is therefore the one from R3. R4 therefore advertises the route to all her peers, i.e. R1 and R3. R1 enters it into its BGP table, but R3 does not because of AS-Path loop.
In the second scenario, R4 still recieves two route, but the one from R1 is the best, as the next-hop is now accessible (thanks to you enabling RIP). Becasue R1 is an internal peer, it is not advertised to internal peers (R1 inclusive).
hope this helps
8 Replies 8
att-sgcops
Level 3
Level 3
and after I apply RIP routing on every router:
R3#sh run | b router rip
router rip
version 2
network 21.0.0.0
network 43.0.0.0
no auto-summary
R4#sh run | b router rip
router rip
version 2
network 41.0.0.0
network 43.0.0.0
no auto-summary
R1#sh run | b router rip
router rip
version 2
network 12.0.0.0
network 41.0.0.0
no auto-summary
R2#sh run | b router rip
router rip
version 2
network 12.0.0.0
network 23.0.0.0
no auto-summary
I found bgp routing table changed: now R4 start to advertise 22.22.22.0/24 with R3 each other and it stop advertise it to R1:
BGP routing table entry for 22.22.22.0/24, version 3
200
12.12.12.2 (metric 1) from 41.41.41.1 (20.20.20.1)
Origin IGP, metric 0, localpref 100, valid, internal, best
43.43.43.4 from 43.43.43.4 (33.33.33.36)
200
can someone tell me the reason?
from R1 and R4 you need to put command neighbor next-hop-self command so that links conneceted to R4-R3 and R1-R2 is reachable via IGP in as 100 R1 and R4.
as in ur output on R1 it says 43.43.43.0 is inaccessible and on R4 12.12.12.0 is inaccessible.
i know there is no next-hop-self cause the next hop inacessible, my question is: why r4 advertised with r1 each other when there is not IGP, and r4 advertised the network with r3 each other when there is IGP (RIP in this case)?
I know your mean, R1 and R4 is connected in the same AS 100. You can see it when use command: show ip route
thanks for your quick reply, but i think my problem is why. I can see the bgp table using "show ip bgp". Please explain to me why r4 stop advertise to r1 and begin to advertise with r3 each other after implement rip.
You wonder about not use RIP but routing information still exchange between R1 and R4. The reason is IGP here use connected status. For more detail, please use command: show ip route
chuongnh
Community Member
Dear Mate,
The reason is you forgot config next-hop-self:
R4(config-router)#neighbor 41.41.41.1 next-hop-self
R1(config-router)#neighbor 41.41.41.4 next-hop-self
Try again with new config ...
Please vote for me !
hope this helps
