BGP question
davidcriollo
I'm configuring this topology
I'm puzzled by R6 receiving R2 prefixes because they originate from a remote AS, so they should arrive with a TTL set to 1. I previously utilized EBGP multihop, but I've since removed it, yet the prefixes persist.
I'm not triying to remove them. I'm just trying to understand BGP behavior.
The prefix of bgp done have TTL
But TTL is mandatory for bgp session to establish.
How can I know ttl in active bgp session?
This info dont find it even in ccie book' you can see ttl of active bgp by
Show tcp breif
There is number appear "pcb" number
Use it in
Show tcp detail pcb "number you get from first step"
MHM
Show tcp breif
Use it in
MHM
