BGP Remove Private-AS
Daniel Anderson
I'm currently labbing a scenario in which I'd like to remove the Private-ASs that are within NLRIs that I'm sending to an EBGP neighbor. The issue is complicated by the fact that within the existing NLRIs, there is a single Public-ASN amongst the private ones, along with the EBGP peerings all being based on Private ASNs. The scenario I'm labbing is below:
AS65000 <> AS65501 <> AS65251 <> AS123 <> AS65001
I've tested the above configuration replacing ASN 65501 with ASN 456, and when I add 'remove-private-as all' to the eBGP peering going to AS65000 I can see that all the Private ASNs within the NLRIs sent to AS65000 are stripped.
What I'd like to be able to do is run ASN456 as a private ASN (as above - and as will be in Production) and still be able to strip out all the Private ASN information, I'm happy I'm running the correct code to achieve this, I just believe that due to the peerings being made between Private ASNs, the functionality isn't available to me.
Is anyone able to offer any assistance on whether a workaround method is available for the above. The BGP ASNs are currently in place within a production environment, so we're unable to change these.
TIA
Peter Paluch
Hello Daniel,
I've  tested the above configuration replacing ASN 65501 with ASN 456, and  when I add 'remove-private-as all' to the eBGP peering going to AS65000 I  can see that all the Private ASNs within the NLRIs sent to AS65000 are  stripped. - See more at:  https://supportforums.cisco.com/thread/2199889#sthash.ieNB03JS.dpuf
- See more at: https://supportforums.cisco.com/thread/2199889#sthash.NZDF6KQb.dpuf
Yes. And if you used remote-private-as all replace-as, all private ASNs would be replaced by your own AS number (though your own AS number may be private, thereby losing the advantage of hiding the private AS).
I do not quite understand this requirement. Isn't the remove-private-as all already performing this operation? Can you perhaps give an example of the AS_PATH manipulation you want to perform?
Thank you!
Best regards,
Peter
milan.kulik
Level 10
Level 10
quite surprising from me it works now with a mixture of private and public ASNs.
But it seems changed considerably since IOS 15.1(2)T, see:
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/configuration/15-sy/irg-remove-as.html#GUID-C2F8C088-6081-490E-AB56-02427BDC7EB9
for details.
BR,
Milan
Hi Milan,
Yes, quite so! I have also been looking at the Command Reference and the changes in the default behavior are quite extensive.
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/command/bgp-m1.html#wp3558926523
Best regards,
Peter
