BGP route issue
TusharMore05872
i am  not getting  ping from PC (172.100.50.51 ) to PC ( 172.100.20.21).....
MY network diagram attached below ..
router 1 configuration:-
Building configuration...
Current configuration : 889 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15246TGH
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 192.100.100.11 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.100.20.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router eigrp 1
distance eigrp 10 15
network 172.100.20.0 0.0.0.255
network 192.168.10.0
no auto-summary
router bgp 65002
bgp log-neighbor-changes
no synchronization
neighbor 192.100.100.12 remote-as 1010
network 172.100.20.0 mask 255.255.255.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Router#
Router#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
172.100.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.100.20.0/24 is directly connected, GigabitEthernet0/1
L 172.100.20.1/32 is directly connected, GigabitEthernet0/1
192.100.100.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.100.100.0/24 is directly connected, GigabitEthernet0/0
L 192.100.100.11/32 is directly connected, GigabitEthernet0/0
B 192.168.10.0/24 [20/0] via 192.100.100.12, 03:33:41
Router#
Router 2 configuration :-
Current configuration : 1024 bytes
version 15.1
hostname Router
ip dhcp excluded-address 172.100.50.0 172.100.50.50
ip dhcp pool Tushar
network 172.100.50.0 255.255.255.0
default-router 172.100.50.1
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524LSP4
interface Loopback0
ip address 10.10.10.10 255.255.255.0
ip address 172.100.50.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.10.10 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router bgp 65002
neighbor 192.168.10.11 remote-as 1010
network 172.100.50.0 mask 255.255.255.0
network 10.10.10.0 mask 255.255.255.0
ip classless
ip access-list standard PERMIT
line con 0
line aux 0
line vty 0 4
login
end
Router#sh ip route
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.10.0/24 is directly connected, Loopback0
L 10.10.10.10/32 is directly connected, Loopback0
C 172.100.50.0/24 is directly connected, GigabitEthernet0/0
L 172.100.50.1/32 is directly connected, GigabitEthernet0/0
B 192.100.100.0/24 [20/0] via 192.168.10.11, 03:36:07
192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.10.0/24 is directly connected, GigabitEthernet0/1
L 192.168.10.10/32 is directly connected, GigabitEthernet0/1
Router 6 (Airtel ) configuration :-
Current configuration : 728 bytes
version 12.4
hostname Router
ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 192.168.10.11 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.100.100.12 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router bgp 1010
neighbor 192.168.10.10 remote-as 65002
neighbor 192.100.100.11 remote-as 65002
redistribute connected
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
10.0.0.0/24 is subnetted, 1 subnets
B 10.10.10.0 [20/0] via 192.168.10.10, 03:38:13
172.100.0.0/24 is subnetted, 2 subnets
B 172.100.20.0 [20/0] via 192.100.100.11, 03:38:13
B 172.100.50.0 [20/0] via 192.168.10.10, 03:38:13
C 192.100.100.0/24 is directly connected, FastEthernet0/1
C 192.168.10.0/24 is directly connected, FastEthernet0/0
(Not getting route of router 2 on  router 1 and viceversa)
your Airtel router is connected to two routers in the same AS ? That won't work, as routes that contain it's own AS are dropped. You need to change one of the AS numbers to something else (e.g. 65003) and also change the configurations accordingly.
router bgp 1010
Hello
Due to bgp loop avoidance the two rtrs runing in the same ASN wont accept prefixes that contain thier own ASN in the sequence number of the as-path, you can negate this loop avoidance if you desire with the following:
both rtrs in ASN 65002:
router bgp 65002
neighbor x.x.x. allowas-in 1010
Kind Regards
Paul
