BGP route-map and prefix list
bapatsubodh
Trying to set local preference using the following configuration:
R2#
R2#term len 0
R2#sh runn
R2#sh running-config
Building configuration...
Current configuration : 1000 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
no ip domain lookup
interface FastEthernet0/0
ip address 10.1.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router bgp 200
no synchronization
bgp router-id 2.2.2.2
bgp log-neighbor-changes
neighbor 10.1.1.1 remote-as 100
neighbor 10.1.1.1 soft-reconfiguration inbound
neighbor 10.1.1.1 route-map apple in
no auto-summary
no ip http server
no ip http secure-server
ip prefix-list hp seq 5 permit 192.168.1.0/24 ------------------------------------- matches only one prefix
route-map apple permit 10 -------------------------------------------------------------  only one match statement in route-map.
match ip address hp
set local-preference 200 --------------------------------------------------------------------- set local pref to 200
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
R2#
R2#
R2#show ip bgp
BGP table version is 3, local router ID is 2.2.2.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 192.168.1.0      10.1.1.1                 0    200      0 100 i ----------------------------------------------------------------- local pref set to 200 as expected.
*> 192.168.2.0      10.1.1.1                 0    200      0 100 i ----------------------------------------------------------------- local pref set to 200 why?
R2#sh ip rou
R2#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, FastEthernet0/0
B    192.168.1.0/24 [20/0] via 10.1.1.1, 00:05:40
B    192.168.2.0/24 [20/0] via 10.1.1.1, 00:05:40
R2#
R2#
How come the second pre-fix is appearing in the BGP table it should not appear as by default route-map should block this?
Please share the experience.
Thanks!
Subodh
John Blakley
Subodh,
It looks like you're matching on an hp access list in your route map. Try changing this to your prefix list name:
match ip address prefix-list hp
Clear your bgp sessions and you should see the correct local-pref.
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
Subodh,
HTH,
John
Thanks. IT was key-word "prefix-list" that was msising.
